I have to keep telling my self the same, over and over. . . impatient old goat possibly. RichRich, You're absolutely right. Thanks for reminding me.
Johan I would not glue any frames to the keel at this stage. I would wait until frame #49 is completed so that you can have a dry-fit of all frames simultaneously.
Hi Johan. Nice to see this picture. And a good idea to sand the latest char when you have the hull complete. Before planking you have to sand her anyway.
And what Heinrich says: first dry-fit till all the frames are done.
Moving right along!More frames...
More frames...
I totally agree with Dean's post. It's fit, fit, fit. With the adjustments always on 1 side. To maintain the regular spacing between the frames. I now see that reflected in my BN at the top shelves with the scuppers. Everything is related. But of course that's with any kit. But good to keep in mind by very frame.Moving right along!
I just stored my frames in the jig until they were all done. I adjusted the tops of the frames to fit in the jig, as I built the frames. I sanded on the same face at the top of every frame, to fit in the jig, that way I avoid changing the space between them up top. Then checked the fit of the frames to the keel prior to gluing everything, and made any adjustments to the keel at that time.
The key is making sure everything goes together snug, prior to gluing it all together. Problem is some of the frames fit the keel so tight, I almost broke them removing to add glue! So be careful! But I think everyone has broken a few frames.
Building up the frames with the keel and the jig is another issue. You have to develop a certain procedure for that yourself. Or make sure that you can tilt the frames in from the bottom and slide them over the keel or all of them in the jig and then place the keel. But then the fit in the keel must already be in order. Fortunately for you and Piero (and the others), there are now several logs with examples, so you are choose the most ‘suitable fit’ for you.Hi Johan ,
I had also considered building in the way you do but I have moved away from that, for the simple reason to avoid breakages
As you can see in my posts I clamped the keel between the 2 slats and the recesses of the frames have been adjusted accordingly.
The result is that you can align the frames more easily and then put them on the keel more tightly with a good view of the frames
After I had all the frames done with yellow tape held together and placed in the mold
Also note the laser cut in the mold is not square, which has cost me an unnecessary amount of time, to repeat the above step
Greeting,
Henk
As I said before, I haven't given myself a specific schedule constraint, so I have no intention turning this into a building competition.PS: Nice to see that you are at the same stage as Piero does. Don’t make it a race, but stimulate each other! With the ‘digital helping hands’ of the others.
I second the comment of Heinrich for your state of mind. RIchThat is a great philosophy to adhere to Johan!
Despite all the uncertainties I'm facing and my anxieties with this build, I want to enjoy this journey, I want to enjoy my successes and overcome my mistakes ánd I want to do things I haven't done before.
So I am frequently checking other builds to enjoy and to learn.
Nice progress but to diverge. . . . I like the dull black cutting mat which reduces/eliminates glare that my green one has and is approaching replacement time. What was the source? Rich (PT-2)Frames #9, #10, #11, #30 and #49 beveled and filed and sanded to fit both jig and keel assembly.
Fixed fit issue of frame #4.
Up to the next batch of frames...
View attachment 281379View attachment 281380
I bought the cutting mat at Pipoos, what you might consider a Dutch equivalent to Hobby Lobby, although not quite so large. A little look around learned that they are also available in the US, Walmart, to name one, but eBay offers also quite a selection.Nice progress but to diverge. . . . I like the dull black cutting mat which reduces/eliminates glare that my green one has and is approaching replacement time. What was the source? Rich (PT-2)
