Tiny update. The fore capstans for the lower and middle gun decks were slipped onto a shaft made from painted 1/4" copper tube, and the wires for lighting carefully passed through the shaft and out holes in the side of the shaft. The lower set of wires will power the lights for the lower gun deck. The others will be routed through higher decks later in the build.
Trunnions for the culverin drakes of the middle gun deck were made for the gun barrels. A hole was drilled in a piece of wood was drilled to the depth equal to the length of wire used to make each trunnion. Then, 18 gauge wire was inserted into the hole and side cutters used to cut the wire flush with the surface of the wood. After 32 cuts, all the trunnion segments had their ends sanded to remove the pinched metal burrs, and then they were blackened and glued into the barrels with CA glue.
The wires will pass through gaps between the false deck pieces, instead of cutting delicate slot in beams and carlings to accept the wires to keep the wires hidden.
Snip snip . . .
Trunnions complete!
Snip snip . . .
Trunnions complete!
bitts and starboard anchor cable visible. The 3mm thick beams look as large as real ones from this angle.
