Before all the beams and supports crowd me out of the gun deck, the hawse pipes for the anchor cable needed to be located and drilled. This was done, and the starboard anchor cable for the forward anchor on that side was installed. The anchor cable was fed through the hawse pipe, with turns over the bit and led back along the deck with the end passed below deck through the grate.
Next, it was discovered that John McCay's locations for the beams, lodging knees, and hanging knees was incorrect when compared Goodwin's
The Construction and Fitting of the English Man of War 1650-1850, which is a more reliable source. Goodwin describes a convention used in the 18th century in which the lodging knees are forward of the beams in the forward half of the ship, and the reverse is true for the after half of the ship since obtuse angled knees are stronger than acute angled knees. This convention should be used since it makes sense and might well have been used in the 17th century as well.
Also, the beams are supposed to be positioned under the gun ports, with other beams between these. McCay's drawings of the
Sovereign violate these conventions. So, DEMOLITION was again necessary to correct the knees. I will not reposition the few beams I have in place, since they are close to the correct positions, but four conflicts between the guns and hanging knees, which have yet to be fabricated and installed, were apparent.
Lesson learned
once again: DON'T TRUST McCAY. He makes pretty pictures, but knows less than he should about ship hull structures. Luckily, the work forward will proceed with me being a tad smarter about placing the hull internals.
The modified Korabel 18th century capstan was finished for the aft capstan. The capstan was recreated as a 17th century style one and installed aft of the main mast. Also, little details needed to be addressed before continuing the beams overhead, such as installing anchor lines and deck rings.
If you guys can think of any other details besides the chain pumps that could be added to this deck before it is closed off, please let me know. This model may not be as correct in every detail as a scratch built POF vessel, but it's getting a heavy duty upgrade from the kit and all these goodies will look great when it's finished. Next are more deck fittings and columns, and I have to scour my other resource books for any information on ladder locations because I don't trust McCay.
Using Payne's illustration and McCay's drawing of the lower gun deck, the positions of the hawse pipes were establish and drill through the hull.
Reworked lodging knee positions. Note the new deck rings and starboard anchor cable. The port anchor cable will be added along with a messenger cable, with its anchor hanging from the cathead as if it is being weighed and prepared for storage on the channel.
Blackened 1.5mm rings and deck hooks made from 18 gauge brass wire were glued into holes in the deck and various positions.
The top section of the capstan was cut off in favor of the older style one made from dowel.
A square diamond file was used to reshape the holes to square shape.
Not bad for a Korabel kit conversion!
Capstan installed.
