Impressive.
This is really a treat, Kurt!I got curious if I could add a few micro-details to the anchor handling gear, so two stoppers were made for the starboard anchor cable, using Wilhem zu Mondfeld as as source. It took about three hours to tie the stoppers in the to the same level of detail using and needle, forceps, and needle nosed pliers. Next a viol block need to be made and attached to the main mast for the messenger line.
While Kurt definitely deserves an award (agree), it is just impractical. Ship modeling is like a chess game: you have to foresee a few moves ahead to avoid 'cutting up' while building...If there was an award for cutting up a ship while simultaneously building a ship...![]()
The whole bashing process has been long journey of "build as you go" steps. It's really hard to anticipate where you will later cut pieces out on a kit's frame structure until you get to a certain stage in building. This is especially true because the model is only my second one. Since research is ongoing as well and construction (and occasional de-construction), there will be features I learn about later than cannot be placed in the ship because the area was built over or no longer accessible. You make changes as you go, and sometimes decide to rework an area that you previously were going to ignore entirely. I have not planned on putting this much detail into the internals, but things got carried away, and there will be almost as much internal features to look at as external ones. Scratch building the tiny details and adding them to the ship each time I read another few pages of John McKay or Peter Goodwin has gotten to be quite fun. I use McCay's work only for suggestions since he made so many guesses as to how the internal structure is supposed to appear which were off the mark, but it's a good place to start for ideas when you have nothing else to go on. Peter Goodwin's book concentrates on 18th century vessels, and it is often difficult to determine if a certain feature is supposed to exist on a 17th century man of war. This books is one you rely on for accuracy. So much changes in 200 years, and lots of guesses have to be made.While Kurt definitely deserves an award (agree), it is just impractical. Ship modeling is like a chess game: you have to foresee a few moves ahead to avoid 'cutting up' while building...![]()
Thanks Paul! It will be great if I can keep the momentum up and make all the decks look like this one. Th research into the basic ship internal structure is new and fun. I almost forgot the chain pumps, but browsing through Brian Lavery's The Arming and Fitting of English Ships of War 1600-1815 reminded me of that and some details I better add before closing over the deck with plywood. Even with all these details, there are loads of things missing with regard to wooden members that will remain missing, but this model will show the basic features. You'll have Wasa done long before the Sovereign is finished. I'm wondering at that point what your next project will be. I have three other ships standing by for building. I'd like to do USS Rattlesnake next. That ship was seriously considered to be my first model before I fell in love with the idea of doing a Renaissance man of war like La Couronne.Kurt,
I have to say that what you are doing with this build is amazing. You have managed to wrestle a POB kit and turn it into a veritable scratch build that has details for days and seeks after some level of historical accuracy. And while the scale is larger than La Couronne it is by no means a large-scale model. Stunning my friend!
looking excellent workThe beams, lodging knees, and hanging knees were completed for the lower gun deck today. I'm still waiting on parts to install the columns.
It got pretty tight working under the poop deck.
Note how the orientation of the lodging knees reverses at midships.
The main capstan can be seen here. The jeer capstan is not yet ready for installation, since the shaft conceals wiring for lighting.
Overall view. Things are really going to get interesting access-wise when the carlings and ledges are made.
It sure is. The ledges are going to be no more than toothpicks.It’s getting kind of tight in there, Kurt.
Hi Kurt,Before all the beams and supports crowd me out of the gun deck, the hawse pipes for the anchor cable needed to be located and drilled. This was done, and the starboard anchor cable for the forward anchor on that side was installed. The anchor cable was fed through the hawse pipe, with turns over the bit and led back along the deck with the end passed below deck through the grate.
Next, it was discovered that John McCay's locations for the beams, lodging knees, and hanging knees was incorrect when compared Goodwin's The Construction and Fitting of the English Man of War 1650-1850, which is a more reliable source. Goodwin describes a convention used in the 18th century in which the lodging knees are forward of the beams in the forward half of the ship, and the reverse is true for the after half of the ship since obtuse angled knees are stronger than acute angled knees. This convention should be used since it makes sense and might well have been used in the 17th century as well.
Also, the beams are supposed to be positioned under the gun ports, with other beams between these. McCay's drawings of the Sovereign violate these conventions. So, DEMOLITION was again necessary to correct the knees. I will not reposition the few beams I have in place, since they are close to the correct positions, but four conflicts between the guns and hanging knees, which have yet to be fabricated and installed, were apparent.Lesson learned once again: DON'T TRUST McCAY. He makes pretty pictures, but knows less than he should about ship hull structures. Luckily, the work forward will proceed with me being a tad smarter about placing the hull internals.
The modified Korabel 18th century capstan was finished for the aft capstan. The capstan was recreated as a 17th century style one and installed aft of the main mast. Also, little details needed to be addressed before continuing the beams overhead, such as installing anchor lines and deck rings.
If you guys can think of any other details besides the chain pumps that could be added to this deck before it is closed off, please let me know. This model may not be as correct in every detail as a scratch built POF vessel, but it's getting a heavy duty upgrade from the kit and all these goodies will look great when it's finished. Next are more deck fittings and columns, and I have to scour my other resource books for any information on ladder locations because I don't trust McCay.
Using Payne's illustration and McCay's drawing of the lower gun deck, the positions of the hawse pipes were establish and drill through the hull.
Reworked lodging knee positions. Note the new deck rings and starboard anchor cable. The port anchor cable will be added along with a messenger cable, with its anchor hanging from the cathead as if it is being weighed and prepared for storage on the channel.
Blackened 1.5mm rings and deck hooks made from 18 gauge brass wire were glued into holes in the deck and various positions.
The top section of the capstan was cut off in favor of the older style one made from dowel.
A square diamond file was used to reshape the holes to square shape.
Not bad for a Korabel kit conversion!
Capstan installed.
