Kurt Konrath
Kurt Konrath
Great work overall. Glad to see you are making use of time in isolation.
**VIEW THREAD HERE** |
thanks, Dear KurtGreat work overall. Glad to see you are making use of time in isolation.
thanks for your compliments, Dear HeinrichSlowly but surely you are filling up that jig my friend - and with each frame that is added, it just looks better and better!
thanks for your compliments, Dear friendGood start and progress, I will try and follow your build!
One of the reasons I use soft (2B) pencil is to have black edges is so it doesn't bleed into wood. Another and a bit more advanced method, specifically used on decks, is black paper! Yes, you hear it right, very good results! However, you need to find thin paper so it will fit on your scale.Right @Jim @Maarten Uses glue which he colors with Indian ink. I also used it partially on the lugger, but the glue sets quite quickly, it works better with black stain, I got the best results with a black marker (edding). However, the colored edge must be very smooth, otherwise it will bleed too much into the wood.
Excellent caulking on the deck, Dan, very clean and accurate work!On joints like the keel for example this wouldn't work too well because you are glueing wood / paper / wood. So in fact the only thing holding the two pieces together will be the paper itself...
Right, thanks for making this point clear. As a means of "visually seperating" the individual timbers on the keel, stem, deadwood etc. the paper method would also be too time consuming. So... The keel structure doesn't require caulking.
Great photos of your work in progress. She is coming along nicely, a testament to your modeling ability.Hello dear friends
For the past three days I have been working on preparing frames 22-19 , with 21-22 being connected frames.
Since the workflow is the same as the three frames that preceded it I will not expand on the workflow, I will let the images speak for themselves.
View attachment 282729View attachment 282731View attachment 282732View attachment 282733View attachment 282734View attachment 282735View attachment 282736View attachment 282737
Wishing us all a continued and enjoyable weekend
