NIcely folded and set however I have a question as to the width of the hem compared with the size of the sail as it appears to my eye as too wide for that size. In full size a hemmed edge would not be more than two or three inches which at the model scale would be much more narrow. Just my eyes and reaction for consideration but yours to fabricate. Rich (PT-2)View attachment 282626
Well my first sail. A little more work then I first thought. But not to bad. For the mainsail I will mix the glue a little thicker. It took to long for the glue to stick will enough to move on to the next panel.
You are more than likely correct. I followed the dimensions that came with the kit. But everything I have seen on line says the hem should be much narrower. I am becoming less and less confident in what this teaching kit is teaching me. The more I progress with this kit the more questions I have and the more time I spend looking for answers. Maybe that’s the point of the learning kit.NIcely folded and set however I have a question as to the width of the hem compared with the size of the sail as it appears to my eye as too wide for that size. In full size a hemmed edge would not be more than two or three inches which at the model scale would be much more narrow. Just my eyes and reaction for consideration but yours to fabricate. Rich (PT-2)
I would suggest that you use a sniff test and think about what is being "instructed", test it out on paper and see the result. Then maintaining the sense and reality of the scale to which you are working, translate that into a full 1:1 understanding and adjust as would be in the correct scale dimension. Some things are too small to do at scale and may need to be enlarged sufficiently to be able to execute them as the smallest size and closest to correct. For some of the small blocks in my Bluenose at 1:64 those were too small for me to able to use so I went up 1/2 or 1 mm in size. The same thing applies to the diameter of the thread/lines with which you are rigging. I suggest to continually think in terms of scale and not blindly or with too much trust proceeding with what you have in the kit. All kits seem destined to be altered, either for practical or builders visual (artistic license) prefrences. Just a thought. Rich (PT-2)You are more than likely correct. I followed the dimensions that came with the kit. But everything I have seen on line says the hem should be much narrower. I am becoming less and less confident in what this teaching kit is teaching me. The more I progress with this kit the more questions I have and the more time I spend looking for answers. Maybe that’s the point of the learning kit.
Let’s see if I get other inputs. I have plenty of material. I not going to build the mainsail until this jib is correct.
Well done on your first sail Duncan.I am with Rich with his advice. Yep I think kits are made to be enhanced, made more authentic and for those experienced guys bashed beyond recognition etc etc.... I don’t think there are too many modelers who haven’t done some changes to their kits. Enjoy it. CheersView attachment 282626
Hello Duncan- excellent improvement. The choice of color etc is always the builders preference-something the guys and ladies on SOS have always encouraged. Something I appreciate. Well done.View attachment 283622
Did some research on sails. Here’s my second shot at sailmaking. (On the left.) Reduce the size of the hemming. It does look better. Also I think I will go with whiter sails. This boat is not that old.
That needle prick was new to me as I have regularly unscrewed the to and inserted the syringe to draw up the glue and then replaced the cap. More of a mess than your less invasive way. I also don't return the glue if I am working with consecutive days which at times necessitates using a very small probe into the needle to clear it out to continue use. As for sail reef lines I just used a needle to pass the precut thread half way through and also used the glue spot to secure it. Such reef lines would be blowing aft depending upon the head wind unless you have a calm day at the pier. Nice progress. Rich (PT-2)Nice technique, Duncan. I'm lazy, so I just squeeze out a glob of glue into a plastic cup and then use a toothpick or old airbrush needle to put the glue where I want it.
You may want to use a small syringe needle or else a needle tip touched in the adhesive and then to the cloth as a smaller contact area. RichView attachment 288150
So far, with this build, attaching these mast hoops was the most time consuming. I had to really blunt the needle so it would not catch the threads that were already looped through the sail. Also next time I have to make mast hoops I will solder the ends together. The rope had a way of finding that little opening in the hoop.
Question. Is there any way of better controlling the drop from those CA micro tips?
