I was looking at your blocks on your gun rigging on the deck below, Kurt. They look out of scale. Maybe you should demolish this deck so you can change them out! I know. That comment won’t even get a rise out of you. Keep up the good work!
OUCH. I admit no one can get blocks small enough for gun tackles, but I bought out the entire supply of 1.5mm single blocks from Dry-Dock Models (and most of the 1.5mm double blocks) for the remaining guns, so at least I'm trying to go in the right direction! :D
You guys who build in 1:48 have it so easy...
What does bashing mean?
It means making large modifications and additions of features to make the model much better than the generic kit. Kits are a good starting place for beginners and intermediate skill modelers to make a detailed kit without having to design the hull from scratch. Halfway through my build, it was decided to gut the entire hull, remove all the original supports and scratch build internal decks. The only thing that will be left is the first layer of planking. Information from research inspired drastic changes in gun port position, deck location, and hull shape. These changes started early with modifications to the shape of the frames, changing the hull shape from bloated and round to the complex hull with curved and flatter areas typical of the period. The stern was radically changed to make it historically accurate.
In your case, it's more like starting over from scratch than it is bashing!
Thanks for the info I thought maybe it meant throwing it on the floor and stomping it to smithereens.
Now I can make sense of it.
Thanks again,
Steven
How did you make the trunnels, Kurt? Did I miss that?
I haven't marked all the trenails on the deck yet. I was doing that with a mechanical pencil containing brown tinted lead. You can see that the trenails at the ends of each plank were done after a batch of tanganika wood strips were cut to make planks earlier in the build. I have a jig with two holes in it that is used to mark the trenails consistently. Making real wood trenails would be too large to be in scale for 5mm wide planks, so I opted to use the pencil. Those trenail marks that were wiped out by scraping will be re-marked.
That is what I did for my deck on the SL.
It is necessary to simulate nails on all boards by the length of the beam .Not only at the joints.there are four at the joints.On the other two nails diagonally.
You are correct. As Kurt said, some have been scraped off and he will put them on again in the same way as you just said. I think something may have been lost in the translation, Andrey. Peace to you, brother.
The margin planks and waterboards were installed on the middle gun deck today, and the remaining planks were installed on the starboard side up to the margin plank. The port side planking is not done yet. The waterboards were made using a 0.3mm x0.5mm strip of wood cut off the edge of a tanganyika strip left over from cutting a 5mm wide strip down to 4mm wide. I had to buy ten strips of tanganyika from Ages of Sail to continue work because Model Expo hasn't received a shipment of that wood from Corel yet, and it's been almost four months. Shipping is pretty messed up from Europe.
Margin plank with waterboard strip
The delicate strip of wood used for the waterboard can be seen in the foreground. The deck on the port side still needs to be finished as seen below.
Progress on the starboard side. Only a few more planks needed to be custom fitted to close the gap.
Waterboard on starboard side
Progress so far
Progress so far
No detail forgotten. I'm building a display - you're building a ship. Respect.
