fully agree.I have always preferred lighter-colored decks - so in my book, this looks good!![]()
yes, water run offThis ought to hold the deck down while the glue dries! The deck curves into a bit of an arch. View attachment 248962
I think I do like the look.a question? do you like the wooden part as you have? Wooed - all types have a lot if tiny holes, which when being painted has this weathering look
There is only one thing I do not like -and is not only you - and THAT IS ADDING THE DECKS AS FAST AS POSSIBLE, which later on in your build -manly Riggen and gun carries. plank the hull first (IN MY OPINION)Here’s where I had to cut deeply into the bulkheads. I also had to chisel a space in the bulkhead for the scab on the back of the joint. Finally, I cot the gun supports so they would fit behind the front wall. View attachment 250015View attachment 250016View attachment 250017View attachment 250018
GOOD AND SIMPLE TOOLSO More new toys! Now I start to play for real!View attachment 251657
Yes, it did cause some problems later on.There is only one thing I do not like -and is not only you - and THAT IS ADDING THE DECKS AS FAST AS POSSIBLE, which later on in your build -manly Riggen and gun carries. plank the hull first (IN MY OPINION)
it works. i have my own recipe, but as there is a dangerous chemical included -i am a biochemist -doing this your paintwork will look much better, as the tiny holes are goneI tried a new (to me) technique of spreading wood putty with a hacksaw blade. It’s supposed to smooth out the hips a valleys better. I’ll let you know how it works out. View attachment 252399
exelentVery nice deck planking work Vic. I like the color of the wood!
looks very good now. I would have added a bow filler tooAlmost done!View attachment 253683
WELL DONE MATENow I can also start to gild the lily…or fleur-de-lys, if you will. View attachment 254030
I SAID IT.Here’s a picture. I’ve got a total of 10 complete guns with carriages going under decking. It will be difficult to place them after covering 8 of them with the aft deck. The forward 2 won’t be as hard to get to. And I can’t finish the hull above the guns before I attach the deck. I know @Gilbertm and @paulb did it somehow. I must have missed it in their builds.View attachment 255565
THAT is my type.Greetings from Brooklyn, Vic. There are many ways to make cannon carriages and their trucks. Some of the techniques will require tooling, but others, are kinda simplified and don't yield the quality and final appliance. For example, the way you made your tracks from a dowel, is the most common of doing weels. I would say it is a classic method. With practice, you will achieve great results!
Because you are entered a new level of modeling called 'kit bashing', you may add some essential tools at your disposal. If you don't have any rotary tools, get one of those. Dremel or Proxxon will be your choice. We had a great discussion recently about what rotary tool to buy. But carefully plan as depending on your choice, the next tool suggestion is a drill stand. Both Dremel and Proxxon have drill stands for their rotary tools. A combination of a rotary tool and the drill stand will make a very important tool - Drill press. Using this tool, you can drill cannon tracks with precision right in the middle. Obviously, if you have a budget you can simply buy a drill press but...
Dremel drill stand and rotary tool may cost you ~ $100.00 (price based on the 3000 Series 1.2 Amp Variable Speed Corded Rotary Tool)
This is just an example of how you can improve the way you work. I am NO WAY want this post routed to the discussion of what tool is better: Proxon or Dremel. Everyone has their own preference\budget on brand\tool they will buy. If you have enough budget (is it possible, enough?????) then you would buy a drill press, to begin with.
As for the present capabilities, you will be surprised by your own capabilities while using the right tools for the given job. Don't underestimate your capabilities! We learn from each other, and it definitely works!
Absolute a beautiful, with even the sails nade correctI want to offer all the builders of the Soleil Royal to see the work of a Polish modeler.Completely self-built, I think.Maybe you can take something into service for yourself. View attachment 257227Forum Koga • Strona główna - Koga Portal - Modele - Żaglowce - Statki - Okręty - Forum modelarskie - Le SOLEIL ROYAL - Koga Portal - Modele - Żaglowce - Statki - Okręty - Forum modelarskie
Malutki chwalipościk pryz okazji prac serwisowych. Całość drewienko. Nie ma tu nijakich odlewów czy innych wynalazków. Taki prawie jak w muzeum w Paryżu Flagi mają monogramy haftowane. Reszta proporców to też hafty, To jako ciekawostka/Przy chwili ps…www.koga.net.pl
here you have the wodden grans. I used a razor blade to get the worst pars away and then sanding.I had to build spacers from scraps to make sure the planks all started evenly across the deck. I’m not crazy about that streak on the grate. I really don’t want to paint it though. View attachment 258761
Good morning Vic. I hope so too. I did the same for my dead eyes but with Indian ink stain. Some of the hemp colored lanyards did change color a little when I fitted the shrouds. Nothing I could not live with tho. Interesting to see how the acrylic and water works. The eyebolt looks good. Does it fit into the channel where you wrapped it by the deadeye? Looking great Vic. You making awesome progress. Cheers GrantI’m hoping the black in the holes won’t rub off on the lanyards.
Why didn’t anyone tell me how hard chainplates are to get them to fit just right? I’m done for the day!View attachment 304321
You answered my question.
