Nice. that would look good as is also.
Please consider making a Donation to SOS to support our continuing growth and developement. It is greatly appreciated !!! *** Read More - - Click Here *** https://www.paypal.me/DonateSOS |
Holy moly - no, Jan! There are till the side pieces, the holes, the handpaken, the knecht and the pal that need to be do done. Then cleaning up, sanding, and treating the whole assembly with shellac and then finding a way of installing it underneath the canopy!Nice. that would look good as is also.
So this would be effort number 7???Holy moly - no, Jan! There are till the side pieces, the holes, the handpaken, the knecht and the pal that need to be do done. Then cleaning up, sanding, and treating the whole assembly with shellac and then finding a way of installing it underneath the canopy!![]()
And counting...So this would be effort number 7???
Good morning Heinrich (you have skills)...must be a South African thing. I think we like the hard and challenging waydon’t forget a set of files and an electric drill (cordless variety) - that's it!![]()
Grant - very hard, very difficult, very challenging. @RDN1954 Johan said earlier he is counting the attempts ... well 7 to be precise.Good morning Heinrich (you have skills)...must be a South African thing. I think we like the hard and challenging way.....others may have different interpretations
. Cheers Grant
Brilliant Heinrich. A very clever way of making the ratchets for the Pal. Cheers GrantGrant - very hard, very difficult, very challenging. @RDN1954 Johan said earlier he is counting the attempts ... well 7 to be precise.
The octagonal windlass just would not work. I actually got two attempts done that weren't bad looking, but it didn't wow me.
And again, @Frank48 Frank was the one who put me on the right path,
The man is a wealth of information and with a period-correct windlass, I could do further research. And indeed.
So onwards I went.
Traced the outline of the side pieces on some stash of Pearwood spares.
Then cut out the shape with an X-Acto knife (yes @dockattner Paul), and repeating the exercise because the thickness of the plywood, necessitated me to double up. Glue is applied to the one side.
Clamped
And emerging from the clamp, is this rather sad-looking piece of hogwash. Or is it? Next step - filing.
Just filed, I only sandpaper right at the before I apply the shellac, the three main components are glued. Note the ratchets in the center which allow the windlass to be stopped and locked in any given position, But more on that later.
Test-fit to make sure that everything fits under the canopy like it should and is in scale.
And here is the knecht (Knighthead) added which carries the pal (no idea of the English name) which locks the windlass by fitting in between the ratchets.
Now when the glue is dry, the holes still need to be drilled for the windlass Levers (handpaken), then everything sanded and then one coat of shellac applied.
Pawl or pallthe pal (no idea of the English name)
Thanks Grant. It simulates it well.Brilliant Heinrich. A very clever way of making the ratchets for the Pal. Cheers Grant
Thanks Hans!Pawl or pall![]()
Thank you very much Thomas. The length of the handpaken (spikes) on the smaller Dutch ships were between 0.90 - 1,20 meter. Taking a length of 1.0meter and then working that back to scale, the spikes actually clear the canopy - during rotation they fit underneath the roof of the canopy. The height of the canopy was 1.70 m.Hi Heinrich!
Please do not push the windlass too much under the canopy? To operate are usually two handspikes (39) in the engagement of the windlass sockets (38). Before a handspike touches the ship's deck, the next one is adjusted from above . This is not possible under the canopy (but just before).
This is just an idea. Perhaps the handspike sockets were offset but also differently?
Best regards
Thomas
While I admire your handiwork, which I could not dream of being able to replicate, I'm not convinced about the location of your windlass. You need to be an acrobat to go from the main deck to the deck fwd of the canopy and back under the best of circumstances, let alone in the middle of the night with a nice, force 10 northwestern blowing.@Thomas Marocke Hi Thomas. NOW I understand what you mean. My apologies - I have been so focused on this part of the build, that I can't even read properly. I even managed quite successfully to destroy my mobile phone in the laundry yesterday!
You are right - you would not be able to change the handspikes below the canopy's roof. I do think I am good though as they almost reach a 90 degree rotation.
On the handspike on the port side, that would be the exact point at which they would change holes.
Thank you Paul - that was indeed a battle!A battle well fought Heinrich. Congratulations.
My position of the windlass is spot on Johan.While I admire your handiwork, which I could not dream of being able to replicate, I'm not convinced about the location of your windlass. You need to be an acrobat to go from the main deck to the deck fwd of the canopy and back under the best of circumstances, let alone in the middle of the night with a nice, force 10 northwestern blowing.
But fortunately I'm not in charge of your build!![]()
Reserving first row, first class seat!However, to rectify that, I will have to build another Willem Barentsz.
