A very happy birthday Jeff.
Thank you.
Thank you.A very happy birthday Jeff.
Thanks, Jim.Happy Birthday, Jeff!!!![]()
Hi JeffT, see if this picture can give you some help WebThe first layer of planking went on reasonably well. As mentioned, I quit nailing which slowed me down somewhat, but I like the result better than the nailed planks. I used a combination of modified clips and thumbtacks to hold the planks in place while the wood glue dried. The clips work well until you get close to closing the hull opening, and then they don't fit anymore.
View attachment 290674View attachment 290675
I used a small plane to reduce the width of the ends of planks near the bow and stern so that I would not have to make as many filler pieces. I still had a few odd shapes to have to fit, but once again the result is OK.
View attachment 290676View attachment 290677
Next steps will be to counter stetting the nails, initial sanding, shaping the stern, and filling low spots & nail holes. Large amounts of sanding have to be done outside the house. We have some reasonable weather in the next week (above freezing during the midday), so I hope to get to it then.
Good morning Jeff. Yep - your endurance is going to come out really good with sanding and filler. I'm sure you are aware it will be a long and dusty ride but a rewarding experience and in your case a chilly one. Enjoy. Cheers GrantThe first layer of planking went on reasonably well. As mentioned, I quit nailing which slowed me down somewhat, but I like the result better than the nailed planks. I used a combination of modified clips and thumbtacks to hold the planks in place while the wood glue dried. The clips work well until you get close to closing the hull opening, and then they don't fit anymore.
Good morning Jeff. I always enjoy the “MacGyverism” modelers come up with as jig, methods etc. Your ladders look great. Cheers GrantNext up in the small items list to be constructed ended up being the ladders (not the deck cabin as previously thought). I struggled some trying to figure out a simple way to hold the sides of the ladders while gluing 1 or 2 rungs in place. I decided to use some modeling clay to hold the siders in place while adding the rungs. This technique, while not very elegant as jigs go, worked fairly well.
Final ladders before and after painting. I used a rotary tool to remove excess brass from the rungs after gluing. A bit of touch up painting will be needed before installation of the ladders.
View attachment 305214View attachment 305215
