Perfectionist?Thanks Dean.
Progress is slow; I have a tendency to overthink certain issues...
Nice work Johan, I enjoy watching your problem solving and methodsAs I wrote earlier today, I would present some background info on how I am adding more detail to the aft cabin.
First order of businesses was to establish the cabin height, since this ultimately determines the vertical position of the two clamps. Why two clamps? Because I wanted to use the same construction principle as is used on the fishhold; clamps attached to the frames, beams on top of the clamps and planks on top of the beams.
Back to the cabin height; I used, quite arbitrary, a standing height of 2m (6.6ft), which translates to 27,7mm (1.1") on the scale of the YQ design. Based on this requirement I prepared a tool to mark the position of the clamps on the frames.
The tool to mark the vertical position of the clamps. I had to remove the center part of the lower part to allow for the keelson and sister keelsons.
The upper edge of the marking tool supported on the deck clamps, providing me a constant distance from the deck to the clamps.
After marking all nine frames, I used a popsicle stick to mark the lateral distance between the pencil marks on the frames.
After some fiddling, I had my measures
I transferred those measures to a piece of paper and by connecting the dots, I obtained the curves for the clamps.
Using a pin, I transferred the points to two pieces of scrap wood of the same thickness as the other clamps, connected the dots and used my dremel to remove the excess material.
For one of the clamps it didn't work out too well, but since I don't have enough material left, I unfortunately have to declare it "use as is".
And now up to the next challenge, manufacturing of the beams...
Good news JohanAnd the Admiral was discharged from hospital this morning!
The empty space filled again.![]()
Yep, the only drawback is that my hands won't accomplish what my mind wants...Perfectionist?![]()
Thanks Dean, it's good to have her home again.Hi Johan, just catching up on build logs. Glad to hear your Admiral is doing well and home again. Great work on the BN so far!![]()
Agreed, however some of the challenges are self imposed because we do embellishments!Thanks Dean, it's good to have her home again.
The BN. build is challenging, to say the least.
So true!Agreed, however some of the challenges are self imposed because we do embellishments!![]()
That’s a nicely build foundation for the cabin floor, Johan. Just in time for catching up the wood by Henk.After some more handiwork, I now have eight scratch-made floorbeams for the aft cabin.
Not throwing out the frame leftovers paid handsomely.
Next step in the build is to add the partial floors for the focsle, the fishhold and the aft cabin, followed by planking the left hand inbd side panel. Coming Friday I'll be picking up the necessary planks at Henk's (@Henk Liebre ), he kindly offered to order those from one of his contacts.
The eight floorbeams dry fitted:
Well done!After some more handiwork, I now have eight scratch-made floorbeams for the aft cabin.
Hello Johan. This is a methodical approach that will have the desired results. Embellishments do cause major re-thinks and extra work - but once finished, brings with them a tremendous sense of accomplishment.
Dear Mark and Heinrich,When you put that much thought and considertation into your work Johan, you are sure to succeed. Looking very good so far
- Mark
An old Dutch proverb:What still needed to be added were the two aft stringers, as indicated in the "Saga". Those stringers are positioned 3ft off centerline. When positioning these stringers I found them interfering with the aft cabin clamps...That's unfortunately a definite no-go. So it was time to remove the clamps. Luckily I used non-waterproof adhesive; just applied a little water, let it soak for a few minutes and off they came and in one piece.
After cleaning up, I did a dry fit of the clamps, the stringers and the floorbeam to check whether or not these elements would cause any further issues.
Another one, often used as well: "meten is weten, gissen is missen" (measuring is knowing, guessing is missing).An old Dutch proverb:
“Met passen en meten wordt te meeste tijd versleten.”
“Fitting and measuring is where most of the time is wasted.”
And if you know everything in advance ……..![]()
For me it goes more like this...I do something and later discover that it's been done wrong. I tell myself, "Whatever. Its good enough" and then every time I walk past the ship my eye is drawn to the mistake like a heat-seeking missile. Eventually I have to fix it as a concession to self-preservation and restoring a modicum of peace back into my life...Dear Mark and Heinrich,
Thank you so much for your kind and motivating words. For me these events start with that I don't like what I see and the desire to add some additional authenticity. (Also inspired by quite a few companion builders here on SOS.) The second stage takes me some time to come to terms with the fact I have to remove parts I already installed, planning the required changes and after dragging my feet a little longer, I finally can't stand it anymore and enter the third stage; implementation of the embellishments.
That's also rather familiar and to great amusement of the Admiral.For me it goes more like this...I do something and later discover that it's been done wrong. I tell myself, "Whatever. Its good enough" and then every time I walk past the ship my eye is drawn to the mistake like a heat-seeking missile. Eventually I have to fix it as a concession to self-preservation and restoring a modicum of peace back into my life...
