Good suggestion. The short answer is that toothpicks are way too thick.Excellent Johan, but I do have a suggestion. Why not use toothpicks for the rungs of the ladder. They would not have been of metal.
It’s looking nice, Johan.Good suggestion. The short answer is that toothpicks are way too thick.
Hmm, let me think...
Good morning Johan. Apologies I always forget to look at the group builds and play some catch up- and I missed your birthday- Happy “very” belated Birthday!! Brilliant work on your Bluenose deserves all the accolades you have received. Cheers GrantTonight I played around (amongst others) with the ladders in the fwd fishhold. I cut two columns from some scrap material, drilled 4 holes (dia 0.6mm) per column at a 5mm pitch, which is equivalent to approx 360mm.
For the steps I used 0.6mm copper wire, which I bonded to the columns.
The picture shows a dry fit installation; the ladders do still need some more adjustments, but I'm happy the direction this is moving.
Once the ladders are finished and installed, my focus will be on the bulkhead between the two fishholds and the installation of the lights for the aft fishhold.
After that I plan to start with the planking of the forward deck and all that it entails.
Thanks Grant, for both your birthday wishes as well as you compliments, I assure you, both are highly appreciated.Good morning Johan. Apologies I always forget to look at the group builds and play some catch up- and I missed your birthday- Happy “very” belated Birthday!! Brilliant work on your Bluenose deserves all the accolades you have received. Cheers Grant
Thanks Paul!Wonderful Johan. I can't even imagine how difficult it must have been to work in this small space and get it all to go together.
Thank you Heinrich!Very detailed work as you are on your way to achieve a very authentic below-deck look. I do not only find the cut-outs convincing but also the complete wall assembly.
A beautiful personal interpretation and solution for these walls, Johan. And yes, it is tinkering in a very limited space.After some hours of tedious labor the bulkhead between the two fishholds has been completed.
It required an enormous number of fit checks, reworks and again fit checks.
One of the issues is that the bulkheads between focsle and fishholds do not have any positive fix in the longitudinal direction. Both sideways and vertical this issue is not present; sideways I could build against what's called the ceiling and vertical the bulkheads are fixed by the lower deck floors and the upper deck beams.
Another phenomenon I encountered was that after applying some varnish on the bulkheads they warped terribly. It's quite simple really why this occurs; the bulkheads are composed of vertical planks, bonded together and an added, to one side only, framework. This means that the bulkheads in themselves are asymmetrical, thus prone to warping.
I suspect Peter (@Peter Voogt) doesn't have this issue: he used a sandwich construction, where the frames are sandwiched between two layers of planks.
The reason I opted for the asymmetrical option is the thickness of the bulkheads; the option I used has an equivalent thickness of approx 140mm in real life, the sandwich option has a thickness of roughly 210mm.
Another observation is that the shrinksleeves, housing the wires for the lighting, are rather large in diameter and that's while using the smallest possible shrinksleeves I could get. Once all deckbeams are in place and the deck completed the wires/shrinksleeves will no longer be visible, not even from the open RH side.
Oh, and before you ask; no, the door does not open, those hinges are fake.
Another bulkhead I prepared is the wall between the aft fishhold and the hold below the aft cabin.
This particular bulkhead was build in situ.
In hindsight the better option would have been to make a template and then build the bulkhead as a separate assembly.
Looking at the picture, I noticed that I still need to add a beam from the top center to the lower left edge of the bulkhead.
I must say that I am quite pleased with how the cutaway of the bulkheads turned out, I find them to be pretty convincing.
Next are to the fwd fishhold ladders and more soldering... Yikes.
That's the beauty of this build; no one exactly knows, so we happily soldier along.A beautiful personal interpretation and solution for these walls, Johan. And yes, it is tinkering in a very limited space.
My reason for planking the inside walls on both sides: The Fisheries Inspectorate came by. Hygiene rules for the storage of fish. As few nooks and crannies as possible where the fish or their remains can accumulate. And flat walls are easier to keep clean.All those rules, rules rules ............ yak!
Thanks Heinrich!Wow - Very impressive Johan - and I love the color of your wood finish - rich and warm!![]()
I'm really pleased with how the lights turn out. This build slowly gets the potential for being an eye catcher.You are working in a steady pace to the aft, Johan. With a well planned lighting plan. They are glowing nicely in the dark.
