the old shipwrights also used the material what they had in the yard ......, but the builders of my ship decided to make them exactly the same size as my mini file.![]()
standard PLA6 hours 12 minutes. What material did you make the arms from
Hallo @ChakotayDespite already being a few steps into the process, I’m starting this build log of MarisStella’s 1/48 Ragusian Cog on the suggestion of fellow modeler Bluebeard, who’s own log of same subject I’ve been following:
His build log has helped me greatly as the kit's instructions are very . . . um, brief (I'll go into this later).Marisstella Cog 1:48
Hi guys and gals: This is my first build log ever and I hope you like my orientations and pictures. By no means I consider myself a “Pro” since I have only built 5 wooden models that later I will post pictures of them. Before my wooden models I built many plastics model ships like many of the...shipsofscale.com
Special thanks to Rick Shousha of Modeller’s Workshop for helping me import this kit to the U.S. from Croatia.
Let me say that the materials of this kit are excellent. The wood (almost all walnut) is top quality. The dowel rods are straight and round. The laser cuts are square (a first in my experience). The cannons are turned brass. The ropes I may actually use (instead of ordering from Syren). I may replace the blocks though.
Work smarter not harderWell, it's been a while. Sometimes I have to step away from a project because I just get tired of it. That "sometimes" can last a few months . . . or years! I took a decade-long break from my Model Shipways Rattlesnake.
It MIGHT be because I knew this next step was going to be a tedious pain in the butt.
The MarisStella Ragusian Cog -- as pictured on the box and laid out in the plans --- has a ridiculous amount of these "vertical side reinforcements" (vertical rubbing strakes?). I thought of a few ways I could do these, ranging from "I'm not putting myself through that" to "quicker & easier, but will look like crap". I decided to split the difference and am doing them this way:
1. Fill the gaps between the wales . . .
2. My table saw doesn't have a titling blade, so I tilt the wood with a smaller piece of wood to give it a little bevel . . .
3. I use a plank bender to give it a curve....
4. repeat . . .
Now I just have to do that 50 more times . . . Will be back!
