Build Log: MarisStella Ragusian Cog
Just when I think I may be getting the hang of this ship modeling stuff I see a build like this that shows me just how much I still have to learn…. This is just excellent execution, talent and skill produces great results!
Now I have to finish out the deck planks. Theoretically, I could have done this before planking (which would have made it A LOT easier), but since the bulkhead extensions need to be thinned down (hence, weakened) I decided to wait until afterwards. The walnut is very stiff and I wanted the extensions to be at their full strength while I was planking. I also use my electric mini-sander to smooth down the inside of the bulwarks.
20220215_170302.jpg20220215_172951.jpg20220214_165309.jpg20220214_164726.jpg20220221_155129.jpg
Decking the forecastle. Unfortunately, the kit doesn't really give much detail as to exactly how this should be constructed. I'm mostly going off the pictures of the finished model in the booklet. So it may not be correct, but this is how I went about it:
First I made a copy of the one schematic you're given in the kit as a general guide.
Shaping up the catheads and some of the other pieces . . .
It's a bit of a rat's nest, but I ran a sanding block over all this to make sure everything is level:
The foremast and bowsprit have to fit in here at some point so I use my Dremel to shape out space for them:
Once I've planked it, I finalize the angle of the bowsprit by taping two pieces of cardstock to match the schematics . . .
When the planks set, I use a razor saw to cut to final shape. Add a small trim piece around the perimeter and cut/sand all the extensions except the catheads...
Since this is a plank-on-bulkhead and not a plank-on-frame kit, we have to add frame detail to the inside of the bulwarks. Pretty straight-forward here: cut walnut strips and glue them to the inside to look like frame extensions. Then sand them all level. The bulkhead extensions that are in the lighter basswood I color match with wood stain (in this case, I use a mix of Minwax dark walnut and classic grey to match my weathering).
20220311_141318.jpg20220311_141334.jpg20220311_141341.jpg20220311_141736.jpg20220311_162139.jpg20220311_163316.jpg
I crush up some artist charcoals/pastels to add to the weathering effects.
Looking good! And thanks for the detail on weathering..(now I know why I should have kept my mortar and pestle.) Detail like that is really helpfull to many log readers. Many logs, mine included, just show pics of work completed which is OK but showing how work is done is really great. It takes a lot more effort though in logging.
Thanks again.
Fair winds.. Ed
Installing the Wales. There's several of them on this model. I didn't have any clamps of the right size or type that would hold them in position so I had to invent and print some on my 3D printer. They're based on the Berna clamps I have but with longer and wider reach.
They have ball joints to conform to the various surface angles. I glued on a patch of craft foam for grip. Then I cut up some carbon fiber arrows for the bars.
The white circles are spacers I printed to ensure even spacing between the Wales...
Despite already being a few steps into the process, I’m starting this build log of MarisStella’s 1/48 Ragusian Cog on the suggestion of fellow modeler Bluebeard, who’s own log of same subject I’ve been following:
His build log has helped me greatly as the kit's instructions are very . . . um, brief (I'll go into this later).
Special thanks to Rick Shousha of Modeller’s Workshop for helping me import this kit to the U.S. from Croatia.
Let me say that the materials of this kit are excellent. The wood (almost all walnut) is top quality. The dowel rods are straight and round. The laser cuts are square (a first in my experience). The cannons are turned brass. The ropes I may actually use (instead of ordering from Syren). I may replace the blocks though.
Hallo @Chakotay
Chakotay, first of all congratulations with your birthday
I have been looking through your build log and love the way you are showing us your construction methods. Very informative. I especially admire your planking and weathering techniques. The colors are well chosen, she is growing into a very beautiful model!
Herman
Well, it's been a while. Sometimes I have to step away from a project because I just get tired of it. That "sometimes" can last a few months . . . or years! I took a decade-long break from my Model Shipways Rattlesnake.
It MIGHT be because I knew this next step was going to be a tedious pain in the butt.
The MarisStella Ragusian Cog -- as pictured on the box and laid out in the plans --- has a ridiculous amount of these "vertical side reinforcements" (vertical rubbing strakes?). I thought of a few ways I could do these, ranging from "I'm not putting myself through that" to "quicker & easier, but will look like crap". I decided to split the difference and am doing them this way:
1. Fill the gaps between the wales . . .
2. My table saw doesn't have a titling blade, so I tilt the wood with a smaller piece of wood to give it a little bevel . . .
3. I use a plank bender to give it a curve....
4. repeat . . .
Now I just have to do that 50 more times . . . Will be back!
4. repeat . . .
Work smarter not harder
