That looks great Adi, great solution with the lengthwise cut.
drydockmodelsandparts.com
I think also, that this is the best way - so the eyebolts at the rail should be installed before at the rope (at the gun)Hi Adi,
I found it impossible to rig the guns in place. I made a little jig and did as much as I could off the ship and then transferred the nearly complete gun into position. Not sure if this is still possible for you or not?
Thanks Paul for your useful advice, this could installation much easier.Hi Adi,
Thanks for your assessment, I will defiitely take it into consideration and do the installation again.To be honest - and friends can be honest .... and I know very well that these guns are very small and filigran although in scale 1:48 (they are only 3-punders)
I do not like it - I can not show it better, because I did not make them until now on my Coureur, but I personally would not be happy with the result
View attachment 335128 View attachment 335129
First I would look for alternatives for blocks and also the rigging ropes on the aftermarket
Check for blocks f.e. the one from Zoly - here you can find 2 and 3mm blocks which should be correct size for the tackles. (please check the size)
Dry-Dock Models & Parts
Dry - Dock Models & Parts is providing high quality ship model fittings and partsdrydockmodelsandparts.com
and also use some other rope material - maybe here also from @Dry-Dock Models & Parts or from Ropes of Scale or others - In Germany we have also a rope supplier (sorry just forgot the contact....)
You will see, that with other material your tackles will look already 200 % better
I was also think about of a tackles not showing the guns "ready for action" but "fixed for heavy sea" - With this, especially because of the very short distance between the single and double block you will get maybe once more 50%
Just my personal subjective opinion without any offense
BTW: The breeching rope should be definitely under the gun tackle
Good evening. This is a beautiful model. Cheers GrantThank you very much for your likes, comments, hints and advice. Especially the latter I have taken to heart.
The result is a second attempt at gun rigging. Zoly's 3mm blocls and MT rigging yarn are used here.
sorry Jim, are you referring to these?I agree with all comments above, great work on gun rigging, and perfect sizing per scale. But...I wouldn't be Jim if I don't point with your permission, a small sizing discrepancy. The quoin handle a bit oversized for the size of the quoin itself. Perhaps, this might be for my own taste.
