Hello Kramer,
Your work is coming along very nice.
Bill
Bill
**VIEW THREAD HERE** |
Good morning. Nice job. Sanding the first layer certainly creates a sawdust blizzard. I did not spend enough time sanding and filling my first layer which made the second planking a little more difficult. I would use wood filler or putty on the first layer as it is easier to work with and you don’t see this. It is also easier to shape to get the hull symmetry just right.View attachment 346401
2 more wedges on the port side and I'm finished with the first layer of planking. Then on to sanding and a sawdust blizzard to smooth out the hull. Along with some wood putty and I'll have the hull ready for the 2nd plank. I've been saving sawdust in a tin. Any thoughts on mixing sawdust with some wood glue to fill in any gaps vs. using wood putty?
Good morning. My rookie experience- check that the planks are strong enough so they won’t lift later. I would use filler in the gaps. That looks like a fairly hard wood? Sapele or birch ? It also looks thick 2mm? I think you could sand this into shape- may take a whileView attachment 346402
And I'm not sure what happened here. This is the lower part of the bow along the false keel. There's a significant gap between the false keel and a few of the planks. Maybe my clamps weren't tight enough or I didn't form the planks enough. Not sure how I'm going to fix this. Any suggestions?
Hey Grant, yes, 2mm thick, and its Lime. I guess I'll sand it down as best I can and use filler if there are any gaps before laying the second layer of planks. Thanks for the help!Good morning. My rookie experience- check that the planks are strong enough so they won’t lift later. I would use filler in the gaps. That looks like a fairly hard wood? Sapele or birch ? It also looks thick 2mm? I think you could sand this into shape- may take a while. Cheers Grant
Good morning. In the photo is looks like a harder wood than lime. Lime is good (easier to work with) and I believe you will be able to shape this good. Enjoy. Cheers GrantHey Grant, yes, 2mm thick, and its Lime. I guess I'll sand it down as best I can and use filler if there are any gaps before laying the second layer of planks. Thanks for the help!
What sort of filler do you recommend? Endurance is my first model and I have just started planking.Hey Grant, yes, 2mm thick, and its Lime. I guess I'll sand it down as best I can and use filler if there are any gaps before laying the second layer of planks. Thanks for the help!
I tried this filler today and didn't have to thin it out. It worked fine. A bit thick but once I applied it and wiped it with a damp paper towel it smoothed out nicely. One more light sanding tomorrow and the hull is ready for the second planking.Hey Lubber! I have this I bought on Amazon. I only used a little on my last hull. It's pretty thick. I just finished the first planking on my Endurance and am going to try and get to sanding and filling today. After I sand, I might try thinning the putty with a little water so it's not so thick to fill in any depressions. If I get to it today I'll let you know how it goes. I've also seen a few posts about using PVA mixed with sawdust as a filler. Makes sense, but you have to think ahead and save your sawdust.
Varathane 215202 Wood Filler, 3.5 oz, Natural
Lovely finish - you've done well there. Thanks for the information.I tried this filler today and didn't have to thin it out. It worked fine. A bit thick but once I applied it and wiped it with a damp paper towel it smoothed out nicely. One more light sanding tomorrow and the hull is ready for the second planking.
View attachment 347516View attachment 347517
Another question if possible... what were the best pliers for removing the pins?Started planking the hull. OcCre instructions say to attach the planks on using the brass tacks and PVA, then to file the tacks down when you're ready to sand. But on the last PcCre ship, my first, someone on the site recommended that I remove the tacks instead and recommended a pair of pliers to help do the job. I did that and am glad I did, I don't think filing the heads of the tacks down would have worked, and if it did it probably wouldn't have been worth the trouble. So doing that again on the Endurance. Learned a trick, push the tacks in at an angle. If you have to hammer any in tight the angle will help you get them out.
Another question if possible... what were the best pliers for removing the pinsStarted planking the hull. OcCre instructions say to attach the planks on using the brass tacks and PVA, then to file the tacks down when you're ready to sand. But on the last PcCre ship, my first, someone on the site recommended that I remove the tacks instead and recommended a pair of pliers to help do the job. I did that and am glad I did, I don't think filing the heads of the tacks down would have worked, and if it did it probably wouldn't have been worth the trouble. So doing that again on the Endurance. Learned a trick, push the tacks in at an angle. If you have to hammer any in tight the angle will help you get them out.
Makes perfect sense, Bill. That's why it's not sticking and is blotchy. Ordering Brass Black now. Thanks for the tip.Hello Kramer,
I think the Perma Blue is a blueing agent that only works on ferrous metals like steel. It will not bond to non-ferrous metals like brass or copper. You might want to look into Brass Back by the same company as the Perma Blue. I have never used these products yet, but that's what I understand. Brass Black is what I plan on using on my Endurance.
Bill
