Tobias, thank you for this as I thought I was doing something wrong after reading the earlier posts. I’ve been using BC Brass Black for many years (not on model boats) and never experienced any bleeding. As you say, dip the brass into the solution (I’ve never had much luck with brushing) then rinse under water, dry off the piece and then buff off the dust. you are also correct that the result is not a deep black rather a burnished “iron” look.Hello Tony and Donnie in the French forum I read the following: it is not advisable to use untreated iron or steel because it oxidizes over time due to the residual moisture in the wood and over time it results in ugly exploitation. When brass is properly blackened, only the copper in the brass reacts and is a type of surface finish. It is important that you apply the browning liquid with a brush, once or twice, then wash it off with clear water and rub off the excess with a cloth. Repeat the process if necessary, the result is not deep black but rather has a metallic shimmer, like untreated steel. You can also oil it a little bit and then there shouldn't be any bleeding into the wood. Treating a nail that is already in the wood is a real challenge, I described it in my La Palme construction diary. Post #149.
I also use Casey's Brass Black for treating the armament. I found that dipping for a minute or so then rising with water, followed by buffing with a old t-shirt gives a nice patina.Tobias, thank you for this as I thought I was doing something wrong after reading the earlier posts. I’ve been using BC Brass Black for many years (not on model boats) and never experienced any bleeding. As you say, dip the brass into the solution (I’ve never had much luck with brushing) then rinse under water, dry off the piece and then buff off the dust. you are also correct that the result is not a deep black rather a burnished “iron” look.
ARCHITECTURE NAVALE CLASSIQUE RECHERCHES EDITIONSI’m curious… I know “Ancre” in French translates to “anchor” in english but the ANCRE web site treats the word as an acronym; A.N.C.R.E. Nowhere on their web site have I found what that acronym stands for. Any ideas?
Are your original printed plans 1:1? Are they printed on B-sized (11" x17") or metric equivalent sized sheets ? Do you have a home printer that can handle lsrge format or will you have to tile the prints? You may want to go to a copy center. And measure your prints to make sure they remain 1:1 if that's what the originals are.Questions for the group…
Based on following your other builds as well as Tony and Tobias on their good start on Le Rochefort your expertise is way above mine. Thanks for being defacto mentors.
1. When making copies of the plans to cut up for laying out frames etc, did you take them to a copy center like FedEx Office and plot them or just use home printer? How do verify that the scale doesn’t change from the original plans?
2. For the assembly frame, do you make a new one for each model or construct a universal jig and make new top frame for each build?
3. I’m vacillating between the Hahn method for making the frames versus laying out the pieces as Sorola shows in his book. What is the consensus is one method more suited to a beginner?
I’m probably overthinking on a lot of this but it is a bit scary jumping into the pool…
Thanks Phil. Yes, the prints are 1:1. They are quad folded and measure 12.25” x 34” I can print 11x17 at home but sold my plotter when I retired. I’m leaning toward taking them to a copy center. It’s just that the nearest one is a 60 mile round trip. I’ll play with options…Are your original printed plans 1:1? Are they printed on B-sized (11" x17") or metric equivalent sized sheets ? Do you have a home printer that can handle lsrge format or will you have to tile the prints? You may want to go to a copy center. And measure your prints to make sure they remain 1:1 if that's what the originals are.
Thanks Donnie and that is true. However I would hope that a blueprint plotter/copier would reproduce at 1:1 but I will certainly check….However, I have also heard that copy machines are set up that they do not make a precise 100% copy - you would have to take some dividers to measure to see any discrepancies.
