Thanks! I’ll look into it…
The table is self-built. I bought a Leuttafel Din A3 on Amazon and bought a table top and milled the plate to fit .Hi Tobias
How do you call (name) your table with LED so i can search it online. I would be interested in buying one.
Thank you !
Daniel
Hello Knut the angle vise I bought from a German manufacturer, Paulimot here is the link to it, I hope it helps you.@Tobias, very good explanation of this working technique, the best I have come up with so far, the milling technique can certainly be used for other models as well.
Question, where did you buy your angle fitting. European supplier?.
Greetings Knut-
I'm interested in what you learn here Olivier - please report your findings!I just placed an order for an angle vise from Micromark. It looks very similar to the one Tobias got in Germany. We’ll see if it fits on the MF-70.
https://www.micromark.com/Two-Way-Milling-Machine-Vise
Thanks Tobias. I was looking at sine plates as well. Or possibly making one. Anyway, I’ll see if the angle vise works and decide from there.Oliver for the MF 70 it is probably too big, but here something suitable for the MF 70.
Product R-PCA-135075-10-4, 25.4 mm × 50.8 mm × 76.2 mm adjustable angle plate with M4 thread
This adjustable angle plate is ideal for holding components at an angle. It can be adjustable up to 160° and has a hard anodised coating, to resist wear and scratching. It is recommended for use on CMMs, the Equator™ gauging system, and vision and multi-sensor machines.www.renishaw.com
I use the 2-axis vise for the large milling machine.
Yes I’ve seen all sorts. Not for $170 MM’s prices leave alot to be desired. ! I have a smaller milling vise on the way. I’ll make something myself.Might check this out at MicroMark
Heinrich, thank you for your flattering words. I am trying my very best.This is once again stunning work Tobias! Oh boy, you guys are talented!
Thank you too Uwe for the kind words. I am a little ashamed but also happy about your words because they give confidence and strength.Very accurate work - very good joints, edges, etc. -> really very good quality of workmanship
I like the small colour differences of the frame elements -![]()
