La Belle Poule 1780 by Thomas
The further assembly with stabilizing blocks.
The bulkheads were finally glued.
All necessary components are firmly glued. After the attachment of the keel, the hull would be ready for planking.
I am bothered by the distance of four centimetres between the bulkheads. I want a firmer and pressure-resistant contact surface for the planking and therefore I got myself an additional six millimeters of plywood.
The dimensions can be drawn on the existing widest neighbouring bulkhead and then the wood can be sawn out and inserted. This results in very little grinding work later on.
Now there is only a blank space of 14 millimeters between the frames.
Best regards
Thomas
Your experience shines at every step of the construction. I can only imagine the lessons you have learned that have brought you to this level of expertise...
Best regards
Thomas
Good evening Thomas. You are meticulous in your approach to building these models. An example to all of us. Cheers Grant
This is what a light bulkhead filling looks like. This is a version I came up with for this model. Between the bulkheads are two mobile spacers. The tools for sanding are hand grinder and belt sander.
Now there is a stable and pressure-resistant support for the planking. When grinding, make sure to still retain some of the laser charcoal on the bulkheads. It marks the exact course of the ship's lines. After planking, they are no longer visible.
The plastic moldings at the bow and stern are still missing for completition.
Here you can see the wonderfully curved ship shape of the frigate.
Now "only" the remaining filler pieces have to manufactored, installed and sanded. This will take some time.
Best regards
Thomas
Best regards
Thomas
You are doing a nice job, Thomas. Nice personal ad-ons for a better planking support.
That's a lovely looking beauty.
It looks as if the kit is well thought out, complete with markings for, amongst other, planking.
Very good idea with the additional spacers - they will be of big help during planking
Looking very good - enough meat but not too much - so Happy Sanding :cool:
Witaj
Teraz łatwiej będzie ci kłaść poszycie na kadłubie , czekam z niecierpliwością na dalsze postępy ,Pozdrawiam Mirek
I am a big fan of filling between the bulkheads - on this ship the extremely thin bulkheads left you no other option.
Hi Heinrich!
The above-water ship is composed of 296 frames. The underwater ship consists of 16 thin bulkheads with four horizontal stiffing boards and the keel. The whole structure of the model is very stable. And that planking can be done on the existing structure shows the models of the manufacturer and Zoly and Donnie.
The additional reinforcements of the bulkheads soothe my model-building soul and of course provide a geat bearing surface for the planks. In the current state of construction, everything is still possible and I like modeling and gladly accept the extra work. Such a beautiful kit of the Belle Poule should of course be appreciated and sometimes requires a little extra work.
Sorry for the uncleaned model, but it still goes on with dust and sawdust.
Best regards
Thomas
Hi Thomas. You can absolutely plank using only the bulkheads - like you say, Donnie and Zoly have done that, but filling in the spaces just makes it so much easier and provides a much larger area for the glue to adhere to,
How do I process bulkheads in an already existing hull?
I use as a guide once the most difficult position of installation parts. Here, plywood parts made with oversize were glued in place.
The most difficult part is the processing of these components, because here no straight files, planes or other tools can be used due to the inward curved bulkheads. With the belt sander running, excess material is carefully removed with the tip at the appropriate angle. The finer work is then done with bend files and final sanding with sandpaper. Very tight curves are sanded by hand with folded sandpaper. Such complicated shapes can only be achieved with patience and sensitivity. Constant checking with a test plank for a perfect shape is necessary.
The reward is a flowing hull contour.
I wish everyone a good weekend
Thomas
Thomas
A very nice and solid approach, Thomas. Check, check, double check.
I was actually going to ask you how you planned on fairing the bulkheads after the fact. You have answered me with a very good solution. You just cannot hurry these steps.
