Your experience shines at every step of the construction. I can only imagine the lessons you have learned that have brought you to this level of expertise...View attachment 350378
The further assembly with stabilizing blocks.
The bulkheads were finally glued.
All necessary components are firmly glued. After the attachment of the keel, the hull would be ready for planking.
I am bothered by the distance of four centimetres between the bulkheads. I want a firmer and pressure-resistant contact surface for the planking and therefore I got myself an additional six millimeters of plywood.
The dimensions can be drawn on the existing widest neighbouring bulkhead and then the wood can be sawn out and inserted. This results in very little grinding work later on.
Now there is only a blank space of 14 millimeters between the frames.
Best regards
Thomas
Good evening Thomas. You are meticulous in your approach to building these models. An example to all of us. Cheers GrantView attachment 350378
Best regards
Thomas
You are doing a nice job, Thomas. Nice personal ad-ons for a better planking support.View attachment 350537
This is what a light bulkhead filling looks like. This is a version I came up with for this model. Between the bulkheads are two mobile spacers. The tools for sanding are hand grinder and belt sander.
Now there is a stable and pressure-resistant support for the planking. When grinding, make sure to still retain some of the laser charcoal on the bulkheads. It marks the exact course of the ship's lines. After planking, they are no longer visible.
The plastic moldings at the bow and stern are still missing for completition.
Here you can see the wonderfully curved ship shape of the frigate.
Now "only" the remaining filler pieces have to manufactored, installed and sanded. This will take some time.
Best regards
Thomas
very accurate & clean work my friendView attachment 351767
The opposite side of the ship is finished. Photo with plastic moldings placed on a trial basis.
View attachment 351763I continue with the underlaying plane. It is easy to see that sanding the filler wood is easier than a completely filled hull.
Best regards
Thomas
A very nice and solid approach, Thomas. Check, check, double check.How do I process bulkheads in an already existing hull?
I use as a guide once the most difficult position of installation parts. Here, plywood parts made with oversize were glued in place.
The most difficult part is the processing of these components, because here no straight files, planes or other tools can be used due to the inward curved bulkheads. With the belt sander running, excess material is carefully removed with the tip at the appropriate angle. The finer work is then done with bend files and final sanding with sandpaper. Very tight curves are sanded by hand with folded sandpaper. Such complicated shapes can only be achieved with patience and sensitivity. Constant checking with a test plank for a perfect shape is necessary.
The reward is a flowing hull contour.
I wish everyone a good weekend
Thomas
