Very cool! Jealous!Took a sail on the 109 year old Lobster sloop “Chrissy” while at Bar Harbor. Nice little sail on a cool little boat. View attachment 253709View attachment 253708View attachment 253710
a bit ? wow, I know this is out of order but the Lanterns were calling my name. I don’t like the fiddly collars the kit provides so I decided to fab some wood ones on my lathe. They will require some tweaking when it come times to mount them but I think they will work fine. Process is listed below
Started with a piece of Cocobolo.
Drilled through and then turned to size
Countoured size to lamp base View attachment 227758
Finished product
I will be able to sand and angle the bottom to fit the ship.
Did I mention I do a bit of woodworking.
Hallo Larry alias @lmcneil1406Well, just opened the box tonight and inventoried everything, all seems to be in order. Removed the keel pieces and filed the edge profile on the first piece. I will try to keep track of build time in the log. I expect to be rather slow and cautious as this is my first ship build ever. I will also have tons of questions as the directions are not so great.
Build Time So Far = 30 Minutes
Larry
oh, the memories!Spent about two hours on this little time sucker! Pounded out some copper wire to make the hinges. Still have to tie off the rope on the ship end but wanted to let the glue dry before that task. Nine more to go!! Thanks for all the nice comments guys.
There is a model shipbuilder who built this same ship name is boilerdan1 and he videotaped it on utube. Was very informativeWell, just opened the box tonight and inventoried everything, all seems to be in order. Removed the keel pieces and filed the edge profile on the first piece. I will try to keep track of build time in the log. I expect to be rather slow and cautious as this is my first ship build ever. I will also have tons of questions as the directions are not so great.
Larry
View attachment 225514View attachment 225513
Hi Larry. This looks rather good. Did you get my last note and my email address.?Spent about two hours on this little time sucker! Pounded out some copper wire to make the hinges. Still have to tie off the rope on the ship end but wanted to let the glue dry before that task. Nine more to go!! Thanks for all the nice comments guys.
Good morning Larry. This is a beautiful rendition of the Pearl. You have a craftsmanship. Cheers GrantWorked some more on the cannons. Still have some finish work to do on them but they’re coming along. Also worked on the ship decorations. Couldn’t fit the brass flourishes above the golden women so I improvised a bit. I tend to do that when it suits me. Sitting at about 110 hours so far.
