HMS Triton - Section - 1/48 [COMPLETED BUILD]
Great work there @Uwek.
I noticed you made a few knotches in situ. Could you tell us about it?
Hallo Peter,
Yes, at this time I did the notches in the beam arms afterwards after they were glued, means insitu.
Here I wanted to be on the safe side about the exact locations etc. .... off course sometimes not easy and with much more care to cut with a small chisel.
The notches of the carlings for installation of the ledges were usually done before glueing in place.....so if you see one on a photo before (without notch) and after (with notch), than it was usually drifting before.
The notches on the beams I did before final installation. Here I put all beams next to each other and marked the areas to be cutted for all beams in the same time. With this the carlings are parallel to the keel, rectangle.
Thanks for your interest ....hope I understood your question correctly and could answer it ....
G'day Uwek
Great going mate. Beautiful craftsmanship is show through with every photo. Just brilliant.
:D
Havagooday and happymodeling
Greg
Dear friends.....mayn thanks for your kind words and your likes. It shows me, that you enjoy the built like I did.
Continuing with the deck planking
The gratings were done with the circular saw, with cutting nodges with the same distance
Than afterwards the same with the 90° turned bord
Today I want to show you some impressions of the finished deck with the grating and the installed ladder.
The location of the beams are marked with a soft pencil, to show the location and direction of the planking nails.....
Good to see here is also the grain of the used ceddar-wood which comes (in my opinion) nicely and somehow correct in scale
Hi Uwe,
I love the cederwood, as you mention the grain looks perfect for a scale version of pine.
Keep this one in mind.
Where did you buy the planks or did made them your selve on a planing machine?
Regs Maarten
Hi Uwe,
Regs Maarten
I think this was a Lebanon ceder. I got the piece from a good modeling friend in Croatia.
I have a very good „home made“ circular saw, so the planks were cut with the saw.
It is time for the installation of the gangways.
First of all the brackets have to be produced out of brass
We need four gangway brackets without Crutch
and we need in addition four brackets with crutch
After the drilling of the holes for the installation bolts they are ready for blackening
