I gueass with planking row 4 or 5 it will be not possible any more on the 2D top view drawing.
Latest when it is going into the 3rd dimension .......
You are absolutely right, this one only goes up to rows 4-5. The rest is pretty self-explanatoryI gueass with planking row 4 or 5 it will be not possible any more on the 2D top view drawing.
Hello Tony thank you for the compliment, I actually have no experience at all with this way of building, which means that I sometimes have to redo things and that requires patience and time from me (which I don't always have). The bow was a problem, insofar as I didn't want to succeed with the milling machine (too little experience with this machine) after 2 attempts I decided to make it by hand, and it was not too bad for me to do it this way do it (by hand) The Stern is also a job that you can enjoy, a lot of fitting and measuring, but you will certainly succeedGreat progress. When I get back in my ship Im not looking forward to the stern and bow sections. they're going to be quite a project to get right !
Tobias , thanks for the quick reply and explanation.Hi Splitter, I think it doesn't matter which finish you use, the wood glue will/can't penetrate the wood to ensure a good bond. I have had good experiences with tung oil, it penetrates the wood well and the color is brought out nicely. Your inner floorboards look very nice, I wouldn't go over them with anything else. Most of it won't be visible later.
Finish with Tungoil
Poly I think gives a thick fake look to wood. Oil enhances it. That’s my opinion anyway.Hi Tony what do you mean with “don’t use poly”
Hi Tony, thank you for your response. I don't know the product "Poly", but if I understand your explanation correctly you mean the "Linseed oil" with this. I have already ordered Tung oil which arrives today.Poly I think gives a thick fake look to wood. Oil enhances it. That’s my opinion anyway.
er knees and breast hooks at the stern have also been cut out. And the mast step half Floor timber is also ready. All drilled holes are filled with 0.5mm pencil lead to imitate the bolts in this way.
Probably referring to poly urethane. But itcan be a great finish depending on the application. It can be thinned and comes in glossy, semi-gloss, and matte finishes. You can try it on scrap first. I prefer brushing lacquer myself.Hi Tony, thank you for your response. I don't know the product "Poly", but if I understand your explanation correctly you mean the "Linseed oil" with this. I have already ordered Tung oil which arrives today.
