- Jan 31, 2021
masterpiece!!!!Folks, I am calling this one done. I have learned alot about POF, and made alot of mistakes and reworks. I will be taking the new found skills to my next POF Kit, CAF LaRenommee, which will have a full internal structure as well. What did I learn from my first POF Kit?
1. Slow Down
2. Each Frame must be Precise to plan, perhaps a framing jig will help. Also still need use of thin battens when fairing the frames correctly
3. Cant Frame angles must be Precise, were hard to see fit in the jig
4. Hawse Frame angles must be Precise
5. Do not attach Stern framing, until last possiable moment, and secure(accidentally broke these off several times)
5. Deck Height must be correct, some what difficult with CAF plan, but do-able(dry fit cabin bulkheads to help Quarter Deck Hei ght
6. Thinking of doing the Deck Beams, ledges and carlings, while still in the jig, and doing each as one complete section(CAF Plan laid all the beams first), making rework when adding ledges and carlings
7. Gun Port Holes must be exact to plan, as it affects placement on knees
8. Angle of quarter window galleries must be correct to fit windows, I saw a tool to measure this after the fact
9. Dry fit everything several times prior to gluing
10. Read ahead in the plans.....the order of build can be changed to accommodate future additions
11. SLOW DOWN-DRY FIT
Fantastic job and I agree with your many points of advice for builders. My scratch built Medea is a sister ship and I watch all the Enterprise builds with great interest and clues to how to go about things. Many thanks.Folks, I am calling this one done. I have learned alot about POF, and made alot of mistakes and reworks. I will be taking the new found skills to my next POF Kit, CAF LaRenommee, which will have a full internal structure as well. What did I learn from my first POF Kit?
1. Slow Down
Ian, I got them from CAF models where I got the kit, they included them, but they are for sale separate as well. They are 1/48 scale as is the kitFantastic job and I agree with your many points of advice for builders. My scratch built Medea is a sister ship and I watch all the Enterprise builds with great interest and clues to how to go about things. Many thanks.
PS - In case I missed it in your build, where did you get your crewmen? I have a few which I have adapted but some of yours I haven't seen before.
Good morning Paul. You have owned it! Cheers GrantFolks, I am calling this one done. I have learned alot about POF, and made alot of mistakes and reworks. I will be taking the new found skills to my next POF Kit, CAF LaRenommee, which will have a full internal structure as well. What did I learn from my first POF Kit?
1. Slow Down
Grant thankyou! on to the next one.....Good morning Paul. You have owned it! Cheers Grant
