**VIEW THREAD HERE** |
I had a great time with the Scientific Cutty Sark.
Viejo, muy viejoAntiguo
How did you do the copper plates? Did they come with the kit?I collected 6 Scientific Kits with great hopes - Sea Witch, the smaller USS Constitution, Charles W. Morgan, Cutty Sark, Sovereign of the Seas and Flying Cloud. Of these I only built Flying Cloud, which I' already posted here somewhere. It's very small, only about 14", 1/24" = 1' and my work with a clipper was not all it could have been, but I've enjoyed the result. I posted this somewhere here before.
Is that newsboy? I think that was a boy band my daughter used to listen to.boy,
I have several of their kits, still in storage and none came with copper, although it would have been appropriate to the model.How did you do the copper plates? Did they come with the kit?
Wow! What a result, even if not considering the small size of the model!I collected 6 Scientific Kits with great hopes - Sea Witch, the smaller USS Constitution, Charles W. Morgan, Cutty Sark, Sovereign of the Seas and Flying Cloud. Of these I only built Flying Cloud, which I' already posted here somewhere. It's very small, only about 14", 1/24" = 1' and my work with a clipper was not all it could have been, but I've enjoyed the result. I posted this somewhere here before.
You're a better man than I am, Gunga Din! My plan at this point is to go with the kit. But who knows, something may catch my eye in the meantime.I kit bashed the Scientific Robt. E. Lee into a model of the "John W. Cannon." Cannon built the R. E. Lee (Three of the same name actually) and piloted her to victory over the Natchez. He built a rather larger and fancier dedicated Cruise ship named after himself in the 1870s. I found pictures on line and got copies from the Floyd Co. Indiana library, and info from the Steamboat museum nearby. I used a book called "the Steamboat Cyclopedia" (If I remember correctly) good for all things riverboat. My model took considerable modification (including a saloon deck foredeck extension over the bow as a promenade for passengers .That and a whole two tier Texas stateroom cabin deck with extensions fore and aft over the Saloon deck. I had the help of a friend with some sophisticated 3d modelling cad equipment, a laser cutter, and another friend with some really nice graphics programs to make colorized copies for the doors and window glass reflections as well as the flags and name plate graphics extrapolated from the black and white copies supplied in the kit and adapted for the "John W. Cannon". the hardest part were the spreaders between the stacks and gluing the whole assembly in place with five minute Epoxy There are pictures on showcase #12
Couldn't have done it without the computer equipment and considerable skills of friends.
Why do you think that? Because it has a solid hull?It seems that you buy the kits by weight....
I got the Charles W. Morgan from a garage sale some years back. Built it a year or so ago and it got me hooked on this hobby. C.W. Morgan is a neat kit, you'll love it. I had to get the New Bedford Whaleboat to go with it. Someone else on this site built it recently too. Go Team!I collected 6 Scientific Kits with great hopes - Sea Witch, the smaller USS Constitution, Charles W. Morgan, Cutty Sark, Sovereign of the Seas and Flying Cloud. Of these I only built Flying Cloud, which I' already posted here somewhere. It's very small, only about 14", 1/24" = 1' and my work with a clipper was not all it could have been, but I've enjoyed the result. I posted this somewhere here before.
The copper plates were made by painting a piece of light weight paper with acrylic Iridescent Copper mixed unevenly with acrylic Green Oxide. Using a paper cutter I cut the painted paper into strips a little longer than the length of a single plate. Then these strips were glued together, with Elmer's, with a slight overlap. When dry, the sheet of glued up strips was turned 90 degrees and cut on the paper cutter into strips the height of a copper plate. These strips were then applied to the hull, again with Elmer's, in belts. In spite of using light weight paper, the final "plates" are still a little heavy for the scale (1/24" = 1' or 1/288) I learned this from Erik Ronnberg, who used this technique for applying copper plates on larger scale models, using actual copper foil and an appropriate adhesive.How did you do the copper plates? Did they come with the kit?
Got pictures?I got the Charles W. Morgan from a garage sale some years back. Built it a year or so ago and it got me hooked on this hobby. C.W. Morgan is a neat kit, you'll love it. I had to get the New Bedford Whaleboat to go with it. Someone else on this site built it recently too. Go Team!
Nice!The copper plates were made by painting a piece of light weight paper with acrylic Iridescent Copper mixed unevenly with acrylic Green Oxide. Using a paper cutter I cut the painted paper into strips a little longer than the length of a single plate. Then these strips were glued together, with Elmer's, with a slight overlap. When dry, the sheet of glued up strips was turned 90 degrees and cut on the paper cutter into strips the height of a copper plate. These strips were then applied to the hull, again with Elmer's, in belts. In spite of using light weight paper, the final "plates" are still a little heavy for the scale (1/24" = 1' or 1/288) I learned this from Erik Ronnberg, who used this technique for applying copper plates on larger scale models, using actual copper foil and an appropriate adhesive.
How did you cut the strakes for the hull?The copper plates were made by painting a piece of light weight paper with acrylic Iridescent Copper mixed unevenly with acrylic Green Oxide. Using a paper cutter I cut the painted paper into strips a little longer than the length of a single plate. Then these strips were glued together, with Elmer's, with a slight overlap. When dry, the sheet of glued up strips was turned 90 degrees and cut on the paper cutter into strips the height of a copper plate. These strips were then applied to the hull, again with Elmer's, in belts. In spite of using light weight paper, the final "plates" are still a little heavy for the scale (1/24" = 1' or 1/288) I learned this from Erik Ronnberg, who used this technique for applying copper plates on larger scale models, using actual copper foil and an appropriate adhesive.
