Good morning. Not much activity on my Xebec. I decided to make some scuppers. I see on the Le Requin they are triangle shaped so went for this. I’m not sure at this scale my Xebec will hold so much detail but I went for it anyway. Drilled a 1.5mm hole and used a small triangle needle file to shape. It was difficult with the veneer to finish them off as the veneer tends to chip. They are 1.65mm and 150mm apart.
Cheers Grant
Cheers Grant
. So I had to insert the Stem.
