Top planking considerations.
The instructions say use instant contact adhesive. In my humble opinion this is bad advice, it gives absolutely no opportunity for correction with instant permanent grab. If you reckon you can handle that...go for it, but not me. The top planks are so thin that they are very fragile, and they are very porous so CA wont grab them most of the time...I do sometimes use CA for this job adding it across and under the plank as I hold it in place but this wood soaks it up too quickly to grab.
SO... I used PVA (again) this time pinning the planks with my pin pusher through a little offcut to hold it for 30 minutes while it grabs well enough to continue. It is working really well after taking a few planks to get the technique right but happy now. The pin holes are not a concern as the hull is painted black, I have dark filler but may not even be necessary.
I probably should have continued improving the finish of the first planking and painted it as I did with Fifie and others. That way you get a full ships worth of spare mahogany planking.
