you are doing wonderful work, and the result are so beautiful and accurateHere are some shots of my progress on the main deck.
Thanks, guys! Appreciated.lovely workmanship, but how would the crew run the cannon back for loading?
My two cents:lovely workmanship, but how would the crew run the cannon back for loading?
rough the brackets and the barrels. The gun was held together with gel CA glue.Very nice work. Was it typical to paint the knob at the end of the swivel handle red?Thanks guys!
I fashioned and fitted 2 swivel gun pedestals, one on each side to the model. These are located over the main mast channels and pass through them. Granado carried 12 - 1/2 pounder swivel guns, each 3 feet in length. The problem is that there is no commercial source available for a half-pounder swivel in 1/32 scale! I'd have to make my own.
I was able to find some brass cannons at Model Expo that were 1-1/4" in length. If I cut off the cascabel they were 1-1/8" - exactly three scale feet. Perfect. The only problem was that the Model Expo cannons had no holes for the trunnions drilled into the barrels. I build a simple jig to drill out the trunnion holes and then turned to fitting the handles.
The first step was to remove the cascabel with a sharp pair of Xuron cutters. I then used the disk sander to smooth and flatten the breech. I drilled a straight perpendicular hole in a piece of hardwood, just a bit slammer in diameter than the cannon barrel. Using a "force fit" I was able to wedge the barrel in the wood so it wouldn't spin when I drilled the hole for the handle. The handles themselves were 3/64" diameter brass rod cut to length with a 90 degree bend at the end. I put a few drops of CA glue, allowing each to dry before adding another, to form the "knob" at the end of the handle. This was painted flat red.
The mounting brackets were made of sheet brass cut to shape and then silver soldered to a length of 1/16" brass rod. Holes were drilled for the trunnion to pass thView attachment 371886View attachment 371887View attachment 371888View attachment 371889View attachment 371890View attachment 371891View attachment 371892rough the brackets and the barrels. The gun was held together with gel CA glue.
Dear DocThanks, guys!
Progress report: I installed the boarding stairs, sweep port lids and the swivel gun pedestals. All that is left on the outside are the channels, deadeyes and chain plates!View attachment 372361View attachment 372362View attachment 372363View attachment 372364View attachment 372365View attachment 372366
