Thanks again rpope and Rob! Feels like this one is heading down the home stretch now.
When I looked at my AOTS on the USS Constitution it shows the eye bolt not having a chain plate, but just bolting thru the channel board. Not saying your wrong and I am correct, but please do proper research before bad mouthing an company on not having proper parts or taking shortcuts.Outside Hull Details
While waiting for my shaper/scraper tools to arrive I did some work on the mast, but I'll stick those pics in later in more or less documented order. For now, back to outside hull parts, and Sea Steps. Twenty of them made from tiny little sticks. you can also see some of the shaped moldings.
Next up are the channels and deadeyes. The method here is to strop some wire around the deadeye and make a longish twisted wire to bend and glue under the channel. Later the ends of the chain plates are just stuck into the holes under the deadeye - they don't actually bear any load. So you have to make sure these things are glued nice and solid under here. I went a little further and scooped out a little furrow for each one for it to sit down in, and flowed some CA down in that. I think it'll hold.
One more mistake is that there are 5 deadeyes + 1 eyebolt = 6 channel slots vs 5 provided - so you need to cut one more. That inability to count extends to the next section and my rant for today.
<rant>
So in addition to the 5 slots in each channel where 6 are needed per side, there are also only 10 chain plates on the etched brass sheet. I knew that if I alerted Model Shipways to this omission I'd get a replacement but it'd probably be weeks (+ now featuring $5.00 shipping!) so I didn't bother and fashioned a kinda crude replacement. Out of curiosity, I looked back on an old build thread for this kit from 2 years ago to see if it was just me, but no, he found the issue way back then, got the extra parts shipped. So, for <<2 YEARS>> MS has known about this missing part and has not rectified it. Add that to also being short the split rings for this step, and the planking shortfall I've discovered, plus it looks like there's not enough brass strip to do the mast, which I can work around - but this is all getting very frustrating. I've now bought 4 kits from Model Shipways. 2 of the 4 were missing Britannia parts (caught at the inventory sheet stage). Now this one short on at least 3-4 items you only discover once into the build. I wonder about the 4th kit now - that's my next build - I'm not encouraged. I'd rate their quality control at the material inventory stage pretty bad right now. Maybe they expect people to put these things on a shelf and not get around to building them and not find all these issues - things don't work like that at my house. I don't know if this is endemic with all kit makers. I guess I'll find out once I start looking at others - maybe my expectations are unrealistic.
</rant>
"One of these things is not like the other". Final pic with channel painted and installed. The one homemade chain plate is obviously not like the others but I'll live with it. I know that technically I should have painted the deadeyes black to match the real ship, but I like the natural wood look - the instructions don't have you painting them either.
Others who have built models and researched the Connie may be able to say what is correct for fasting of the eyebolts.
Looking at the segment of the instructions you provided, I can see where there could be confusion. Where they say 6 jackstays and 6 split rings, is that 6 on each side, or 6 total with 3 on each side. It's not very clear.
Good looking build.
