Hi Johan, naturally the hardest block to make is the best looking one (to me) with the wire strop.
I should have known...Hi Johan, naturally the hardest block to make is the best looking one (to me) with the wire strop.
Those block’s are so tiny, those fingers are so big, the wire is so unwilling, the tools are mostly so of position ……. It’s hard to manage all to a satisfying result. But you will succeed, Johan. You will!I am now entering the stage where I need to start stopping the blocks. Having seen quite a few examples of modelers producing believable stropped blocks, I wanted to give it a try as well.
Below three tests with some old blocks I still had lying around. Not easy to get a satisfactory result.
The main gaff requires the installation of a few stropped block, so I decided to start manufacturing the blocks for the main gaff. The results were discouraging.
The two pictures below are from the same three blocks, the lower block being slightly different, I repositioned mentioned block to clearly show it's looks.
The top block shows the iron wire strop. This material requires an awfull lot of patience and manipulating the block and strop simultaneously is a real pain.
The mid block is stropped with 0,6mm rope; way too thick and clumsy looking.
The lower strop is made from 0,3mm rope; more convincing, compact, but also more "fuzzy" than the iron wire.
The rope strops are rather easy to fabricate and a drop of CA helps tremendously to maintain the shape of the strop. I'm afraid I'll need a couple of days to decide upon my next step w.r.t the stropping...
View attachment 372671View attachment 372672
I'm not sure. In itself the wire is rather easily to form, but forming it around a 3mm block, or 5mm for that matter, is a nightmare. As Peter (@Peter Voogt ) mentioned; too big fingers, too small blocks, tools hard to keep in position... I also tried copper, slightly larger in diameter and stiffer, thus harder to form around those blocks.Have you annealed (softened) the wire? That should make it easier to work with...
Good morning Johan. Have you checked out HisModels? He has pre-made strops for blocks in black or brass. They really look good. If it didn’t take a year to get to me I would buy some? Cheers GrantA bit earlier than next year...
Ran a small batch of 5mm blocks. As yet I can't convince myself of the esthetics; functional, yes, but esthetically so wrong:
Still considering using rope instead... To be continued.
Thanks for the tip, I'll check it out.Good morning Johan. Have you checked out HisModels? He has pre-made strops for blocks in black or brass. They really look good. If it didn’t take a year to get to me I would buy some? Cheers Grant
Ordered a few pre-made strops for trials. If successful, the rest of the blocks will follow suit.Good morning Johan. Have you checked out HisModels? He has pre-made strops for blocks in black or brass. They really look good. If it didn’t take a year to get to me I would buy some? Cheers Grant
Good afternoon Johan. That is such a wonderful description of the truth. . Let me know how they go because if good I may just order a whole pile and wait….and wait . Cheers GrantOrdered a few pre-made strops for trials. If successful, the rest of the blocks will follow suit.
Delivey time is about four working days, so that's not too bad.
I guess anything getting shipped to SA goes by canoe, hence the year lead time...
Transport to the Netherlands: they chuck it into the Danube and fish the package out of the Rhine, once near.
I will most definitely share my experiences with these strops.Good afternoon Johan. That is such a wonderful description of the truth. . Let me know how they go because if good I may just order a whole pile and wait….and wait . Cheers Grant
The delicate rigging has started! Nice job, Johan. Good to see you have chosen a sequence that fits to you. Every one has it’s pros and cons.While waiting for the first (experimental) set of strops from His Models (the shipment is underway, delivery pending the Danube flow towards the Rhine), I had some time considering the build sequence. Initially, as I mentioned a few posts back, I wanted to do some of the running rigging and sail installation, before installing the shrouds and stays. Evaluating this sequence, I had to adjust my ideas for the following reason: installing the stays and shrouds first gives a rigged and steady base to start the running riggin and the sail-install. Postponing the standing rigging to a later stage of the build may very well cause the masts to be misaligned. A second reason is the accessibility of the shrouds at the tresseltrees. The more running rigging is installed, the more the accessibility to the shrouds is obscured. My fingers being the size they are, that's not something I'm looking forward to.
So I found myself starting the installation of stays and shrouds. Right now I have three stays in place; two stays between fore- and main mast and one stay from the bowsprit to the top of the lower fore mast. In order to be able to install the stays between the fore- and main masts had to install the top mast shrouds, at least at the top of both top masts. (Still following?) According to the Model Shipways drawings, the stays between the masts are positioned on top of the top mast shrouds.
For the top mast shrouds I used the "swifter" method, as described and used by @Peter Voogt .
Stay from bowsprit to top lower fore mast:
Two of the three (top) mast stays in place:
Detail of the main top mast, with the topmast shrouds in place; the shroud, running from the top of the npmast to the railing is not yet tensioner. The swifter configuration is hardly discernable, too bad it was quite a tedious job:
That's a true statement!Good to see you have chosen a sequence that fits to you. Every one has it’s pros and cons.
I don't understand that yet, but we'll save it for laterEvery one has it’s pros and cons
For sure it's a work of love, otherwise one wouldn't last a day with this build (and many, many others like this...)Certainly nice work Johan
I don't understand that yet, but we'll save it for later![]()
Good morning Johan. Looking very good. ….and now the fun starts…While waiting for the first (experimental) set of strops from His Models (the shipment is underway, delivery pending the Danube flow towards the Rhine), I had some time considering the build sequence. Initially, as I mentioned a few posts back, I wanted to do some of the running rigging and sail installation, before installing the shrouds and stays. Evaluating this sequence, I had to adjust my ideas for the following reason: installing the stays and shrouds first gives a rigged and steady base to start the running riggin and the sail-install. Postponing the standing rigging to a later stage of the build may very well cause the masts to be misaligned. A second reason is the accessibility of the shrouds at the tresseltrees. The more running rigging is installed, the more the accessibility to the shrouds is obscured. My fingers being the size they are, that's not something I'm looking forward to.
Agreed, although installation of the three jib's are not the biggest issue in this case. Routing the hallyards and sheeves of the jibs and belaying them is another issue.In addition, you need the stays for your jib sails.![]()
