Grants Xebec 1:60 (using Jabeque Cazador Occre1:60 kit) [COMPLETED BUILD]
Good morning. We have had some beautiful winters days and have capitalised on this while we can- not much Xebec time.
The rudder : This little bugger fought with me hard….I had to reshape her due to my hull shape changes, redesign the Occre kit fitting etc etc.
Grants design. Not accurate however I was not going to fill the notches on the stem. Just looked ugly. So the kit was modified.
1. The rudder had to be cut and reshaped to fit the false keel
2. The rudder was bevelled on each side
3. The notches in the rudder were filled with cut out walnut. The kit pins were too large so I used 6mm copper pins. These are supposed to fit perfectly into the notches on the stem. ROTF- Did what I could.
4. Extended the top of the rudder as my hull changes made this all longer
5. Used the kit hinges. I would have preferred them narrower, however I had to go with what I have. Acid, Roughed up and painted with primer paint. Man I need to get some brass black. Will be an expensive mission but I’m over my brass painting efforts.
….and of course where the tape was left a change of wood colour:mad:. I’m sure I can sand this off and hopefully will not be seen when I put poly on.
Tiller :
Rounded the edges of a 4x4 walnut, wet, heated and shaped with curve. I added a little handle to assist my crew for fun.
The whole mechanism actually works….ROTF
Cheers Grant
That's a very nice rudder, Grant. And there is a 18th Century ship with this type of rudder: see the SoS-site and search for "Grant+Xebec".
For me no problem at all.
About this, You mean the import costs? I suppose there is a gun-shop in Cape Town. I am sure they have it.
Good morning Peter. ROTF. I’m not sure Grants design would handle a small squall in the Mediterranean.
Yes. I can order on Amazon however need to use DHL or similar and this costs plenty. Then it sits at our customs and they add another 50% onto the charge. If I use normal post it never gets here or 6 months later. I have looked at gun stores and they are all out of stock and “don’t know when next delivery arriving”. I will get some though, a big bottle which hopefully will last- I don’t know the self life of this. Cheers Grant
Grant, I feel your pain on both counts. Painting brass metal black isn't a whole lot of fun as I am now discovering, and placing any kind of faith in the SA postal system is even less fun. I hope you get what you're after though, and then you can show me how this brass blackening process actually works. Good luck! :)
Grant try checking out Jewelery making stores and your every day model hobby shop. They may have a product called "JAX" it can patina in a variety of colours from Black, Brown Green etc for either Brass, Silver or Copper.. It's a very good product range. - BTW nice work on your Xebec. Thumbs up. Thumbs-Up
Good morning Mark. I’ve tried almost everything to paint brass and it doesn’t really work. I will get brass black or some product which can patina….or just pay R3000 for a bottle. Lol costs more than my kit ROTF . Cheers Grant
Good morning. I will search here for this. Thank you for the advice:D. Cheers Grant
Good morning.
Cheating time :D :
I know I cannot whittle wood as those magicians Peter (@Ptèr ), Dean (@Dean62 ) , Maarten (@Maarten ) and many others do. The kit decorations do not fit my Xebec in any manner so I cheated and bought a resin 3D printer. Lol it was cheaper than the three 3D Parts I bought for my Victory….go figure.
To design correct and accurate designs one needs to buy a CAD program and go to universityROTF. For Grants Xebec Im just going to download some free STL files and create some decorations. I will have “go to University” before my next ship which hopefully will be a historical replica. I have missed the research and discovery aspect of this hobby with this build.
My theme - Lion and eagle. After splicing (Using Lychee splicer ) this is what came out.
All stuck on with Prestick and painted with antique brass. Sorry Dean @Dean62 and Paul @dockattner ,no artistic dry brushing and fancy work- just dip and paintROTF.
4F41F010-B402-4310-8F0D-F4B2766EA80C.jpeg7B399828-DF6B-4892-A8B8-F3A794EFE615.jpeg4639BA92-7C73-44AE-AFC5-E929916D11AC.jpegCA21D01E-AA8C-4A4C-ACFA-EBDFEA20B967.jpeg
Modelling- I framed the stern with walnut, and the underneath with Sapele veneer. I have basically run out of 1mm walnut left overs from the Victory so no redos available- Eish!
Problem….The emblem,only free STL I can find, of a lion and an eagle which shape works, is the Armenian emblem….what a landlocked country has to do with a Corsair Xebec who knows Redface. Ah well let’s see- was fun.
Cheers Grant
Grant, now you have me thinking about buying a 3D printer.
