1/350 Akagi Hasegawa - Completion of a project long overdue
Incredible work, Nigel. The PE set for this kit is pretty amazingly detailed, and I would say mastery is already your domain.
Thankyou very much Mark.I do look at some of the 1/700 work on YouTube and I am humbled.The photo etch kit for this was THE kit at the time.I look at this though and compare it to the Tetra set I have for the Fujimi Kaga and think the Tetra set trumps this.
I also have the Trumpeter Piotr Veliky missile cruiser in the stash and the Five Star etch set.The photo etch radar arrays in that set are mind blowing and will cause me much frustration when I eventually come to build itROTF There are pictures on Youtube of the kit with set built by a Russian modeller and it is incredible
When I first started model making,I remember seeing jaw dropping pictures of 1/700 ships with all the railings etc made from stretched sprue, that really is talent
Kind Regards
Nigel
I encountered an issue when trial fitting the front superstructure in that the pins no longer lined up with the holes on the deck.This used to do but over time since I built this section things have moved a little:oops:My solution is to remove the locating pins and fill the holes in the deck.I did try to flex the short legs but the styrene has become brittle and it resulted in a snapped leg which I had the glue back on.
As I had replaced the kit deck to allow me to drill the tiny holes around the base of the superstructure,I had to replace the ribbing.This has been reinstated using Evergreen styrene section
Kind Regards
Nigel
Make no mistake Will, will all the additions, this kit is a mammoth task. I had no photo etch experience when I started this, by the time I finish it I feel I will have mastered the artROTF
Kind Regards
Nigel
Nigel, Just worked through your build log. Very impressive PE work especially since you say no previous experience! As always, masterful approach to everything you do. I'm following - have the Indianapolis and Iowa on the shelf - along with upgrade packs.
Thanks Bill
I have spent all weekend snake charming photo etch.The remaining parts have been fitted to the front section of superstructure and the railings fitted to the foredeck.My aim is to head towards fitting the forward flight deck/superstructure
Kind Regards
Nigel
It's definitely becoming the PE standard to measure. Snake charming that's a new one I think I'll use it.
Thankyou Will
The second from top one had to be fed inside the front columns as it was one single length. The air was blue numerous times as the little railing feet snagged on anything and everything
Kind Regards
Nigel
The fact that the railings are perfectly straight is a testimony to your mastery over PE. Bravo!
Thankyou Paul
I chose to use the Eduard railings for the deck because they have a continuous bottom rail to glue to.Only issue is that the relief was to large for the raised section of the deck edge so I have to increase the height of this section with some 0.5mm styrene square rod
Kind Regards
Nigel
I have dusted the metal parts with Mr hobby metal primer and then applied some light coats of Tamiya LP13 Sasebo grey.
These pictures are very "warts and all" and show the raw painted finish of the photo etch.The paint will be left to fully cure for at least a week and then the rough areas and visible glue will be toned right down with a combination of fibreglass pencil and pieces of 1500 grit sanding sponge before applying another hit of Sasebo grey
Kind Regards
Nigel
Thanks Will, the jackstays are an insane amount of work though and as I said only a small improvement over the kit moulded detail which looks really good with a black wash.No matter how hard I try, I cannot get them perfectly straight given the cramped work area and the minuscule size of them.
Kind Regards
Nigel
Kind Regards
Nigel
Yeah, it definitely takes a knack to draw-out sprue to specific fine diameters. I love the steel-navy stuff; it's a different form of complication, more akin to watch-making, than the baroque ornament of our beloved Frenchies.
Kind Regards
Nigel
View attachment 386451View attachment 386452View attachment 386453View attachment 386454
Whatever a fiberglass pencil is, exactly, it sounds like something I need to possess; a pointed abrasive?
BTW, I echo Paul's sentiments about your railings and PE work, generally - brilliant stuff!
Thanks Marc
Below is the fibreglass pencil I use for fine polishing of painted areas that are awkward to sand.Cheap as chips from Halfords in the UK so easy to replace when they loose their effectiveness
Kind Regards
Nigel
View attachment 387105View attachment 387106
Nigel, I've never seen these before - just ordered a set from Amazon! Love trying new things ;) And, your jackstays look great - very fiddley things for sure.
Thanks Marc
Kind Regards
Nigel
Hi and good morning. Excellent work your doing on this model so much to be admired PE wise. My question, do you wear a mask while using the fibre-glass pencil and is that the Vallejo pencil?
Thankyou and no I don't, The amount of sanding dust produced is microscopic and never gets the chance to be airborne as the process is so slow and light.No this isn't a Vallejo product, just one meant for automotive chip touch ups.
