Incredible work, Nigel. The PE set for this kit is pretty amazingly detailed, and I would say mastery is already your domain.
Thank You. I haven't heard of Alliance model works. Let my search begin again.
There are pictures on Youtube of the kit with set built by a Russian modeller and it is incredible
Nigel, Just worked through your build log. Very impressive PE work especially since you say no previous experience! As always, masterful approach to everything you do. I'm following - have the Indianapolis and Iowa on the shelf - along with upgrade packs.Make no mistake Will, will all the additions, this kit is a mammoth task. I had no photo etch experience when I started this, by the time I finish it I feel I will have mastered the art
Kind Regards
Nigel
It's definitely becoming the PE standard to measure. Snake charming that's a new one I think I'll use it.
Thankyou PaulThe fact that the railings are perfectly straight is a testimony to your mastery over PE. Bravo!
Yeah, it definitely takes a knack to draw-out sprue to specific fine diameters. I love the steel-navy stuff; it's a different form of complication, more akin to watch-making, than the baroque ornament of our beloved Frenchies.Thankyou very much Mark.I do look at some of the 1/700 work on YouTube and I am humbled.The photo etch kit for this was THE kit at the time.I look at this though and compare it to the Tetra set I have for the Fujimi Kaga and think the Tetra set trumps this.
I also have the Trumpeter Piotr Veliky missile cruiser in the stash and the Five Star etch set.The photo etch radar arrays in that set are mind blowing and will cause me much frustration when I eventually come to build itThere are pictures on Youtube of the kit with set built by a Russian modeller and it is incredible
When I first started model making,I remember seeing jaw dropping pictures of 1/700 ships with all the railings etc made from stretched sprue, that really is talent
Kind Regards
Nigel
Whatever a fiberglass pencil is, exactly, it sounds like something I need to possess; a pointed abrasive?I have dusted the metal parts with Mr hobby metal primer and then applied some light coats of Tamiya LP13 Sasebo grey.
These pictures are very "warts and all" and show the raw painted finish of the photo etch.The paint will be left to fully cure for at least a week and then the rough areas and visible glue will be toned right down with a combination of fibreglass pencil and pieces of 1500 grit sanding sponge before applying another hit of Sasebo grey
Kind Regards
Nigel
View attachment 386451View attachment 386452View attachment 386453View attachment 386454
Nigel, I've never seen these before - just ordered a set from Amazon! Love trying new thingsThanks Marc
Below is the fibreglass pencil I use for fine polishing of painted areas that are awkward to sand.Cheap as chips from Halfords in the UK so easy to replace when they loose their effectiveness
Kind Regards
Nigel
View attachment 387105View attachment 387106
Hi and good morning. Excellent work your doing on this model so much to be admired PE wise. My question, do you wear a mask while using the fibre-glass pencil and is that the Vallejo pencil?Thanks Marc
Kind Regards
Nigel
