Nigel that woulds be wonderful of you to help. I spent yesterday reviewing the SSmodelkit pe it appears to be very complete, 12 sheets in all. Thanks again
Hey guys, I am new hear I found this thread actually from wills IJN cruiser aircraft carrier build, and I gotta say I love both of your work and hope to be sharing mine with you all soon, I'm working on a 1/350 USS New Jersey post 1981 kit it's the largest scale I've ever built. But that's not what made me want to comment it's actually your drill bit discussion.Micromot 50E with transformer. I like it because it is so lightweight and easy to hold, almost pen like.
I get my drills from drill-service.co.uk. These sizes are not cheap, I can buy a set of DIY drills for the price of one of these
Kind Regards
Nigel
I look at your work and realize what I have ahead of me. You set the standard for me to achieve.I have had a little break, now back on with things. I decided to focus on completing the bow deck and superstructure section. I forgot how many layers of detail there are to add.
First job was to metal prime and then topcoat the area where I had two platforms to fit and I did the underlying structure whilst I was at it.
After this, I installed the two platforms I made earlier, well actually several years ago.The tabs on the platforms had to have the back edge trimmed to allow the platforms to slide in, marked with the arrows
I added gussets underneath from Allianz Modelworks universal set and the remaining details to these areas. The etch Paravane cranes were funOnly one included in the Eduard set so good job I have two sets!
Kind Regards
Nigel
View attachment 385143View attachment 385144View attachment 385145View attachment 385146View attachment 385147View attachment 385148View attachment 385149View attachment 385150
As I mentioned earlier these are the micro drill bits or what's left of my recent set. The smaller ones are very fragile and don't take side loading well so I wind up breaking at least one each build, fortunately they are cheap enough I can just run to the store an pick up a set or two for sparesView attachment 383861
This is just one half of the set there is another box similar to this with the slightly larger sizes. Let me know if you guys would like me to send you the store link. I hope this could be helpful
I honestly can't imagine what you would need anything smaller then the smallest bit in this kit as it's like Insulin needle thin but I haven't got to the skill level your at yet so maybe it's yet to come for me but I'll say this if it's smaller then whats in the kit I'm not sure I'd bother lol cause I'd surely break the bit in the attemptI have bought similar sets before, only issue was the smallest drill wasn't small enough
I didn't think of this but now that makes sense, though I'm pretty sure in my kit my smallest bit would be able to do the job though I've never specifically tried. If I had a jig/template for marking holes for ladder connections it might make my job of attaching them alot easier, this is something I might consider and experiment withI use 0.18mm drills for the ladder rungs, smallest in the kit I bought was 0.3mm and yes they do snap easy
Yes the North Star rungs came with a template, no way I could have drilled the holes otherwise to anywhere near the accuracy requiredI didn't think of this but now that makes sense, though I'm pretty sure in my kit my smallest bit would be able to do the job though I've never specifically tried. If I had a jig/template for marking holes for ladder connections it might make my job of attaching them alot easier, this is something I might consider and experiment with
Just catching up on your build log Nigel. You are making steady progress.
Painting the PE beneath the deck the IJN grey seems to be a tragedy. The shiny PE was like a piece of modern metal art. A question, the railing on the below video what PE kit is it from?
Thanks Nigel. It's looking fantastic.
