Happy Birthday for Sunday Johan. Hope you had an awesome time. Cheers GrantHappy Birthday, Johan!![]()
**VIEW THREAD HERE** |
Good morning Johan. You look like you have been working that machine for years...So, being 69 years of age and none the wiser, I started my 70th year with the fabrication of yet another sail, the main topsail.
For now the process is as follows:
1. Stain the cloth and let dry.
2. Transfer the lines of the previously prepared paper template the cloth.
3. Stitch (straight) the seams, simulating the sails trips being stitched together.
4. Next the edges of the sail, again straight stitches.
5. Again stitching the edges, but now with a zigzag stitch
All stitch are done with the smallest possible settings (1 on the Admiral's Etna, no clue what that means, but could be mm's.)
6. Apply diluted woodglue on the sail and set aside to dry.
7. Once dry, cut the excess material, just outside of the outer zigzag stitches.
The first sail was trimmed with a pair of scissors, may be I'll experiment with cutting, but not sure yet.
8. Finish the sail by adding the necessary hardware, prior to setting the sail.
Pending on my experience the process may vary...
Step 3, main topsail, the dummy seams:View attachment 385159
Step 4, stitched the net edges of the sail:
Step 5, the zigzag stitch applied, left and right of the stitch made in step 4:
The next steps will be shown later, once reaching those steps.
A shot, taken by the Admiral, of a man-at-work:
Thanks Grant, I had a great day, beautiful weather and beautiful company.Happy Birthday for Sunday Johan. Hope you had an awesome time. Cheers Grant
Thanks Shota, 69 years of age and still learning…Happy Birthday, Johan
wish you all the best and happiness
tha sails looks great
The sails remain a royal pain. I just completed the fore sail, which saw quite some puckering and I don’t know why. I used the same cloth orientation, same stitching sequence, same rope, essentially no changes to any settings and still... Plus, due to the puckering, I also noticed quite some shrinkage, especially in the vertical and no amount of ironing or somewhat forced stretching did me any favors.Sails are looking good Johan.![]()
I’m definitely gonna try that one!Say Johan, I read somewhere, maybe on this forum to attach a thin paper like tissue wrapping paper to the material with straight pins. Once you finish sewing pull the paper out and the tiny void that's formed is enough to release the thread tension thus relaxing the pucker. This sounds like a real pain, and I have no idea if it really works but may be worth a test try.
Oké, I decided to share anyway.Once I have collected my courage from the dustbin, I might take some pics and share, but that could be a long way coming…
I understand your hesitation about the foresail. Options: always look at it or .......Oké, I decided to share anyway.
I haven’t come to a decision yet with regards to the foresail, but I think I know what I did differently from the main topsail; I applied the diluted glue to the foresail after stitching, which means the cloth was rather supple and thus more prone to puckering.
I attached the sail to the gaff and boom in order to get some insight in how it looks. Like I said, undecided for now, although the Admiral is wondering what I am whining about…
Still considering ripping it of the boom and gaff and starting anew, but before taking that decision, I’ll do a couple of ratlines instead.
Both foremast sails as they should appear:
Good morning Johan. Whew sails....! I have never tried and now I am even more fearful of this process when I get there. You and I are so used to redos by now we should write a journal on thisOké, I decided to share anyway.
Right now I've made five sails, of which three, possibly four are scrap. Apart from the puckering, I also found the fore sail to be too small, height wise. Redo time it will be. Since I have limited to no knowledge about textile and weaving of textile, it's all new territory.Good morning Johan. Whew sails....! I have never tried and now I am even more fearful of this process when I get there. You and I are so used to redos by now we should write a journal on this. Leave it for a while and if you don't like it....rip it. Cheers Grant
We shared some WhatsApp's on the subject; to be continued... I'm afraid that after all is said and done, I'll be a rather experienced user of the Admiral's Elna.I understand your hesitation about the foresail. Options: always look at it or .......
I also just started over on several sails.
Considering the rest of your BN's look, it's well worth it.
Perhaps on a next D.B.B.S. a picture of us, both behind the Admiral’s Elna’s ………….We shared some WhatsApp's on the subject; to be continued... I'm afraid that after all is said and done, I'll be a rather experienced user of the Admiral's Elna.
Nice picture Johana shot taken by the Admiral, of a man-at-work:
I think on the dustbin fore sails I had about 0,4"/10mm shrinkage. The third fore sail was close to nominal.The right-hand side does look very good Johan. I was amazed at how much a fabric will shrink up when done sewing all those straight lines. I had to oversize quite a bit 1/4 to 3/8" so they would come out close to the correct size.
My respect, Johan, for your perseverance to ultimately achieve the desired result of a representative sail. It’s looking very nice.After having made 1 main topsail, 3 fore topsails and 3 foresails, I now finally have an acceptable sail...
The six dustbin model sails were a) not really looking well and b) dimensionaly too small, especially the fore sail.
The only thing I didn't try yet was Dan's (@Daniel20) suggestion to use some tissue paper to reduce the tension in the fabric. I am somewhat reluctant to do this: I fear that, after tissue removal, the stitches may become too slack, maybe unfounded, but I just don't know.
The Admiral suggested to increase the stitch pitch by one step, I think it went from 1 to 2mm, I followed her advice (as every good spouse does) and the result was a significant improvement over the earlier versions. I also stitched, with the sewing machine and a nice zigzag, a rope to the sail for the luff, leed, foot and head.
To the left is a dustbin version of the fore sail, no need to explain why...
The fore sail on the right is the first acceptable one I made, albeit not 100% perfect. Increased stitch pitch and rope stitched to the edges of the sail.
