…….you guys are driving me to booze and anti depressants….You're not that fragile, Grant...
Understood. Just not on the same night please...…….you guys are driving me to booze and anti depressants….![]()
Hi Nomad, regarding gunboats, from a manuscript of the time.Hi Nomad, sorry for my observation, the fighter gunnery (towards the bow ) have a different angle than those on the broadside.Frank
You definitely don't need us to do just that...…….you guys are driving me to booze and anti depressants….![]()
@Frank48 - does this mean there would NOT be a gunport cover on the most forward hatch?The British open this hatch on most of their vessels. "
Hi Paul,what I understand on the main deck the gunboats do not have capes . Frank@Frank48 - significa che NON ci sarebbe una copertura per il portello delle armi sul portello più avanzato?
Good morning Mark. It is cool when the guys in the know debate aspects on our logs. So much information is shared we learn plenty. So….lid or no lid?Wow, I've been away for a while and have just returned to all this discussion and debate on gunport lids. It is all very interesting and thanks to those for taking the time to nut it out. The research you do on this sort of thing is very credible. Unlike my own research, which only extends as far as looking at other builds of the same model and, on aggregate, following their lead. But it has certainly given me food for thought, why some gunports have lids, or not, and the reasons for that. Thank you indeed for this input and your interest in my HMS Fly![]()
Some will have lids, other not. Got to be diplomatic, keep everyone happyGood morning Mark. It is cool when the guys in the know debate aspects on our logs. So much information is shared we learn plenty. So….lid or no lid?. Cheers Grant
To me @Uwek 's comment made a lot of sense and gives a very plausible reason to have lids or not.Some will have lids, other not. Got to be diplomatic, keep everyone happy![]()
Good morning Mark. Those are tiny hatches. The joinery is fantastic especially considering the size. You must have the measurements for the top decks exact to start the fittings prior to placement. I would be hesitant to do it this way as I would probably break off the fittings when gluing the deck onThe dockyard and all work on my HMS Fly has been very quiet of late but there has at least been some signs of activity. Most of the upper deck fittings have been assembled although all still dry-fit at this stage. The companionway ladder leading from the quarterdeck is likely to interfere with a grating on the gundeck below. I had warning about this, fortunately, and had made appropriate adjustments to the hatch size earlier on. The upper half of the capstan nestled nicely on its counterpart below.
Binnacle, skylight and hatches. I notice many modellers apply a glaze to the window frames to emulate glass panes. Very classy. All my window frames got were a couple of hinges to suggest that they can be opened
The tiller and housing was reasonably straightforward, although it may get a bit more interesting when I get round to rigging it to the ship's wheel.
On the forecastle deck...
The hatches, which I assume to be steam hatches for the galley and stove below, are very, very small indeed. Still, I was determined to assemble them in the same manner as the larger hatches by ensuring that the corners of the combings are connected in half lap joints (blue circles), and that the longitudinal timbers of the hatch when viewed along the deck fore and aft are uninterrupted as they pass through the athwartships timber notches underneath (red arrows)
The upper decks have not been glued in place yet. I need to make sure everything that needs doing on the gundeck is done, and possibly the bow section work as well before makling that commitment.
Thanks for checking in
Mark
Very precise work Mark. I love your color management, especially with the grate combings.The dockyard and all work on my HMS Fly has been very quiet of late but there has at least been some signs of activity. Most of the upper deck fittings have been assembled although all still dry-fit at this stage. The companionway ladder leading from the quarterdeck is likely to interfere with a grating on the gundeck below. I had warning about this, fortunately, and had made appropriate adjustments to the hatch size earlier on. The upper half of the capstan nestled nicely on its counterpart below.
Mark
Nicely added parts on the deck, Mark. In terms of construction and painting.The dockyard and all work on my HMS Fly has been very quiet of late but there has at least been some signs of activity. Most of the upper deck fittings have been assembled although all still dry-fit at this stage. The companionway ladder leading from the quarterdeck is likely to interfere with a grating on the gundeck below. I had warning about this, fortunately, and had made appropriate adjustments to the hatch size earlier on. The upper half of the capstan nestled nicely on its counterpart below.
The upper decks have not been glued in place yet. I need to make sure everything that needs doing on the gundeck is done, and possibly the bow section work as well before making that commitment.
Mark
