Short answer about finding a source, no.Hi Stephan,
The edge bending tool seems to work great.
As far as I know on the actual ships I haven t found anythong that edge bending was actually done. More sawing the plank in the correct shape from a bended tree trunk.
Have you found a source that edge bending was done?
Now THAT is a true statement - especially on the Dutch ships where the shipwrights adopted a much freer approach!There is to much we don't know about how these ships where build.
So true Heinrich, we just don't know. I think every shipyard in the Netherlands had a different approach. Even the books we have from Cornelis van Yk of Nicolaes Witse are questionable. Cornelis was a builder and did I think 7 years to write the book. He was a shipbuilder. Nicolaes only 2 years and he was no shipbuilder. It seems the pinas he wrote about was a Fluit actually. A writers mistake by the source he was used. And there is much more to study and read and still keep a lot of questions. Besides these questions and mistakes in the books, they still are a treasure chest of knowledge, I'm glad whe can read and study them.Now THAT is a true statement - especially on the Dutch ships where the shipwrights adopted a much freer approach!
Thanks Johan, I soak the planks a minimum of 24 hours under water (tip from Marcus @flying_dutchman2 ) and when I need an extra high in-plane bending I use a little boiler water before I bend. Works fine. Just take your time bending no rush, to avoid split. The I leave that to dry. Depends on the water conditions how long. But I let it dry till it is about 90% of the stage it was before soaking. Then I get the plank out of the clamps and start bending the other direction on the model. When the shape is right I place the plank on the ship after another hour of drying. When I need just a little bending I soak it inwater a shorter time. You need to experience this.Still very impressed with your "edge" or in-plane bending. I did some mild in-plane bending and it was rather tricky, especially when one has to do bending in two directions, like your planks on the Hohenzollernmodel. I can see why pre-cut planks may give a builder severe headaches; once the grain direction doesn't follow your bend plank curvature, you'll introduce stresses normal to the grain direction, with split planks as a result.
I am also wondering whether or not your experiences can be directly extrapolated to a full scale model, thus giving us more insight in the old shipwrights' way of building.
Thanks Heinrich, very nice comment. In the post I react to Johan I discribe my method of bending. Hope it is clear.Wow two excellent postings guys - first by Stephan on his exquisite and painstaking build and secondly, by @RDN1954 Johan for the very valid probing questions. This is quality participation and discussion at its best. @Steef66 Very interesting comment Stephan about Witsen's "pinas" versus a fluyt. I did not know this, but if this is so, then it would explain certain issues that I have had all along with Witsen's "pinas". One thing I have learnt is that the name or ship type ascribed to Dutch ships, often mean nothing. The ship of Willem Barentsz has been a called a "Jaght", "Boot", "Carvel" and "Vlieboot".
Hey Stephan,Thanks Johan, I soak the planks a minimum of 24 hours under water (tip from Marcus @flying_dutchman2 ) and when I need an extra high in-plane bending I use a little boiler water before I bend. Works fine. Just take your time bending no rush, to avoid split. The I leave that to dry. Depends on the water conditions how long. But I let it dry till it is about 90% of the stage it was before soaking. Then I get the plank out of the clamps and start bending the other direction on the model. When the shape is right I place the plank on the ship after another hour of drying. When I need just a little bending I soak it inwater a shorter time. You need to experience this.
Sometimes it split a little bid, no problem, just a little dilluted White glue in the split and a little clamp to close the split. After sanding no problem to see.
If this build can be projecten to a real ship build? I don't know. Could be but in bigger scale there is a lot more that can be done. When you search on youtube there are a lot of video's of woodbuilders that build like this on small boats. So everything is possible because I seen a similar build like mine on a cano.
And the bad news? He's not he only one around here...Stephan makes me dizzy too...
Guys, guess you have to stop drinking.And the bad news? He's not he only one around here...![]()
Many, many, many thanks Ken.Stephan, I've been out of circulation for a bit and just now getting caught up, on reading only.
I admire the projects both you and Maarten are working on. I understand the history and pride you both have in building those unique Dutch Fluyt ships. The work you take on in this project, as it, I suspect it was with the actual Dutch shipwrights a combination of science and art. I think you you have to be able to use both left and right sides of that brain of yours to go into analytical mode when needed and then switch gears and fire up your creative/artistic side, which this project most certainly requires.
As stated by others, super progress you've made.
Now, I can only imagine of someone not familiar with wooden ship modeling seeing the picture below that they would become dizzy in the head. I'm not sure, but think I counted 6 different fastener types, some of which you made yourself. Pretty impressive all around. All I have to say. Wonderful work.
I agree with Maarten, maybe the A.A. is a solution for you guys. But I have to warn you. It isn't anonymus at all, the first time I got there I recognize almost everybody there.Guys, guess you have to stop drinking.![]()
