Thanks , Oh yes they’re shortened by now. Frame 30’s bottom is a little short compared to the plan. I’m going to cut it and add a longer bottom. That may work. I wasn’t clear on the bottom lengths when I cut them previously.
Thanks Tobias. I stop in the check progress on occasion. I haven’t touched it since March. I work in construction and although semi retired the winter is the only time when I have much time to build. Also been working on my planes which I love.Hi Tony, how are things going with Le Rochefort? We would be delighted to see you back soon.
Good morning Tony, nice to hear from you. We would all be happy if you could work on Le Rochefort again soon. Good luck finding the saw you want. Thank you !
Yes agreed. We’ll see how it looks in the next week.1st when taking off you need to make sure of the run.
2nd you need the ghosting line on each rib
In other words one frame shows the next.
3rd too much wood left to remove + all those nicks in the ribs.
4th detail ? What I can see no detail to the rib construction.
It can be done.
A lot of sanding / faring the timbers.
Depends if seen or cover up?
Bottom can just have the run.
If sections - I strongly suggest removal and sanding to fare. Very painful.
Of course if you have golden hands …. ?
Yes Oliver we do love it ! I think milling and fitting the floors is key to get that keel and keelson joinery accurate then put the frames completely together . I agree the keel assembly is quite some project in itself. I need to get a surface planer so I can control my thicknesses easier. Also the Proxxon FET or the Micromark clone. Without the saw I’ll be struggling like I did on Blandford section. So much time wasted working with the smaller Proxxon. It’s useless except for very light light work. ThanksTony, I feel your pain. This is my experience in starting over…
Once I had lumber milled to sizes I started on the keel assembly. It took about 3 weeks time and about 80 hours work for me to complete the new keel assembly and keelson as I really went slow and built several practice pieces to be sure of my mill and cutting setups. Next I laid out all the new frame templates and glued them to my planks which took me three days and about 12 hours work. I just finished rough cutting out all the pieces which took about 6 hours work on the bandsaw which included replacing the tires and retuning the saw. Now I’m ready to start sanding and assembly of the frames. My plan is to get all the pieces sanded to the layout line, assemble the floors and mill the floor “saddles” that fit in the keel and keelson. Once I’m satisfied that the floor pieces all fit I’ll complete the frames.
That’s as far as I’ve planned for now.
Don’t know if my experience in starting over helps or not. Best wishes for fair sailing! Remember, we do this because we enjoy it!
My pendulum may have swung to the extreme due to my previous attempt with the attitude of “close enough”. This time I’m striving for zero deviation from the drawings.Ok, looking at my frames against the plans. They are certainly not perfect on the money. How much of a fudge factor do I have here ? Not much I’d think.
