The capstan is amazingly built. Bravo, Rick!
Very nice Rick, looks great rounded,WIP-----
Finished Capstan before final attachment to the Hull..........................................................................................
Big difference with the cannon Rick, the new one's look much better, did you have to modify the carriages much,WIP------
Onto the next order of business..................................................
Like our fellow modeler Maarten, I am in the process of replacing all of the kits 8 cannon barrels. I am extremely disappointed in the quality of the kits Canons. For one thing, they are not period correct and every one of the eight are visibly warped!!!! One would think that based on the kits cost & the Cannons being one of the more visual eye grabbers, the kit manufacture could have supplied much better Canons!!!!!
I purchased the Brass Barrels from Cornwall Model Boats Ltd out of England and I purchased the Monograms from Syren Ship Model Company.
More on this coming soon.........................................................................................
Hello John,Big difference with the cannon Rick, the new one's look much better, did you have to modify the carriages much,
Best regards John,
Thank you Rick, for the info, I've got my cannon all assembled so I've got to see if I can get the barrels off with little damage, will see what happens, thanks again,Hello John,
Period gun barrel
Length 50mm, diameter 8.9mm
Product Code: RB01150
I can only agree with Heinrich. Fantastic build Guns with every detail correct, as a UK-rigged gunWhat do you get when you mix the most commercially available detailed kit in the world and one of the most experienced shipbuilders on the forum? Answer: The magnificent Royal Caroline that we all have the pleasure to view on these pages!
Just beautiful, my friend. I had a lot catching-up to do but every minute of it was more than worthwhile.
fantastic build deck with its capstain , water pumps and many more detailsWIP----
Just some quick pics showing the completion & placement of the decks eyelets & rings. I will glue in the Gratings, Capstan, Bilge Pumps and the Main Topsail Sheet Bitts/Gallows after I get the Cannons installed & rigged (will be nice having it all out of the way)!!!!!
Onwards we go........................................................................
agreThese guns a very good - all necessary details included - very good work
I recognized the eyelets which are wood-screws - it will be not possible to drill them into the bukheads, so you have to predrill the hole with the outrer diamtere of the screws
