The project left well and I am impatient to see the continuation - I understand now is the great season of football. Why not benefit from the two pleasures ;-) (football& scale modeling)
G'day Zoly
Great progress mate. Good idea about foam, I'm going for balsa wood. Like you I like a solid foundation for the planking.
Glad to see that you used the word 'soccer' not FOOTBALL. Lol
Havagoodone
Greg
The project left well and I am impatient to see the continuation - I understand now is the great season of football. Why not benefit from the two pleasures ;-) (football& scale modeling)![]()
Hi Zoltan. Be careful when sanding the foam, easy does it, as it is much softer than the bulkheads it is easy to end with waves instead of a continuous curve, if you see what I mean.
JL
Hello Zoltan
Very interesting the way that you are using the foam to stiffen up your ship, this sure will help in planking her up. Got a question how do you use CA and glue in your build? Just curious, ENJOY.
Regards Lawrence
Do you file and sand those to shape? I use a hot foam cutter when I build and shape my scenery.
If you use wood-glue it is off course an advantage of you use any soft wood for these parts, so you can use the same type of glue.My experience tells me that I'd rather use balsa at the bow and stern.
Or other soft wood.
JL
