Wicked good!
Hi Richard , found on the net, might be of some help.FrankThanks guys
You are correct in that assumption Jim, there is absolutely nothing that needs to be soldered to them and those that do need fixing have enough area to CA on.
The only small fitting which needs to carry load are the boomkins and those can be pinned through.
Looks like I will be experimenting with milling aluminium on the CNC soon.
On another note I am playing with the idea of publishing this as a set of plans and templates that can be replicated at various scales to meet increasing demand for smaller scales.
What I am proposing will cost a little more than regular set of plans for the simple fact it will not be done on paper, the reason is paper moves.
I hope you all know this but you should never print on paper.
Plans should always be printed on drafting film, it is stable, semi transparent and heavy gauge making it tough and ideal for cutting with a knife and running a pencil around it.
View attachment 417112 The other huge advantage some of you may not realise is the ink used on film is almost like a wax and if ironed face down will transfer on to the wood
It can be shipped anywhere regardless of climate and it will not move.
The bonus of this is I don't have to limit you to my choices of timber although I am adamant of this personally, Anigre for decking as it looks identical to aged teak and American Cherry stained with golden yellow stain to replicate the golden brown of varnished teak.
But ultimately its up to you. Can I have some thoughts on this.
an example of this would be the frames and keel, I would provide each frame as a normal profile with the bevel also marked on it so it can be glued onto the ply cut out and bevelled with a file.
This was done in the same way before I owned a CNC and with care note the quality of the fits.
View attachment 417113View attachment 417114
The keel would be the same with the addition of 1:1sections at every frame and waterline, of the rabbet on a separate sheet that can be cut up.
rather than the frame notches being marked on keel I would mark the location of one side of the frame, to allow for users to supply a different thickness of frame, something along that line of approach
The accuracy of the model will not be compromised in any way, it's still as close as a shrunken version of the full size thing but users will just have to be good at scroll sawing and cleaning up to the very fine lines which will be very fine lines indeed .13mm or finer.
I would not think that anything smaller than 1/64 could be built to the proper level of detail, things would have to be dropped or scaled up to make it possible. though.
I would include plans for everything on the hull and masting, including the decking and planking and optional cast resin fittings.
Or am I stupid doing this and better off just doing proper plans of the ship at every level and letting you build your own and come up with you own construction method.
Can I have some thoughts on this from everyone?
Hello!An extremely interesting project Richard and something we have in common, I was also involved in the restoration.
Hello!
I probably have you in a photo somewhere then....
Do you remember Claire or Shirley E?
Thanks Frank, she was barely recognisable at that stage of her career, looking very sad.Hi Richard , found on the net, might be of some help.Frank
SORRY for my writing error , I meant to say : THINK ( intend ) and not sink, about the 1:48 and 1"50 scales.Hi Richard, congratulations on the models and projects.
What do you sink about making the Cutty Sark kit, also in 1:48 or 1:50 scale, were it would be very easy to find ready-made parts, on the market ?
Sorry I missed this question. I will explain what's involved from my end first.What do you sink about making the Cutty Sark kit, also in 1:48 or 1:50 scale, were it would be very easy to find ready-made parts, on the market ?
Thanks for your answer. Certainly a change of scale in your project would be very laborious without practical results, since it is not your objective to produce the kit in large quantities. Best regardsSorry I missed this question. I will explain what's involved from my end first.
Please keep in mind I did not go into this with the goal of a mass produced kit, if I did I would have gone to 1/48 I was asked to do this as a one off at 1/40 and am trying to see who else are happy to do it at this scale
However I will explain what's involved to do another scale.
The model creation in 3d takes 3-4 months as I can only do it part time, I spend all day modelling in 3d for my job and in the interest of losing weight I have to get off my butt after work to get moving so that is the first thing, and because the first rule of kits like this is identify your exact plywood thickness first .
every different scale requires a large amount of re modeling as frames for 1/40 1/48 and 1/50 would probably be the same but 1/64 would be smaller, ,even so the other parts still have to be done, then there is the machining, it takes 5 full days to machine 1 kit with one day of that maintenance as the CNC requires full calibration and adjustments after every 20 hours.
The material alone for a 1/40 is about $400AU as I use Finnish aircraft ply which is very high quality, the 4mm is 8 ply..
I did ask a few questions back (post 18) how people would feel about a set of plans and patterns that can be scaled to what scale you want and printed on Mylar drafting film, I still think that is the best way to do this, Honestly this is a detailed kit and probably not for those who don't want to cut out parts as it has to be done regardless.
I have heard that most people with this kit in mind would not want to cut out frames but in all honesty that's the easy part, if the patterns are accurate and include all the info and are stable and don't shrink/contract in moisture which Drafting film doesn't.
I might even be able to get it with an adhesive backing.
I should add that the size of some of the elements at 1/48 is near impossible to create and you have to fake it or make the out of scale.
But if you have patterns you can do what ever scale you like I just need to tell the printer and he can print that version.
I don't think you would be able to get parts for this kit other than the obvious things like blocks and belaying pins.
I built this ship at 1/48 when I was in high school in the 80,s and it was very hard to do the fine work, the gingerbread work and things is nearly impossible but at 1/40 its able to be done quite well in resin and gilded or painted, I would gild it as gold leaf is not that expensive and its an easy process.
The deck planking at 1/40 in only 3mm wide and laying and joggling a deck any smaller than that is tricky to do well. But again if somebody decides to do it smaller they can do a ply penned in deck if they wish though I can't stand them personally.
So I guess I really want to know if patterns is an option, in my mind the advantage to this kit or plans is not having the work done for you, it's having a really good construction design and an accurate exact scale representation of the ship.
As I said back in post 18 I could also just do a set of plans of the ship as built and sell those but I think the design of the structure is actually the hard part, until you see all the subtleties of her it will not seem like that but trust me it was not easy to resolve even at 1/40
If I just give plans of the model and patterns you can even decide to plank it a different way, such as double layer if that floats your boat.
This client wants it planked properly on one side and coppered on the other, at least that's what I think he has planned.
I have not priced it yet but at a guess I can't see it being cheap, like any other kits it would be above $1000.
I thought they only said that in South Boston. Ha!Wicked good!
I am from Maine…a common Maine saying…as in “That pizza is wicked good!” South Boston is a bunch of flat landers!I thought they only said that in South Boston. Ha!
