Dave, to print them in scale, they would effectively be extremely thin and would be too fragile. On the pictures I posted, they have not been cleaned up yet. They do look a bit better once cleaned. It would be fun to try and redo the panels out of metal but I would use thin aluminium, much easier to work. I have some .01 in stock, that would come to 1/8 in scaled up. Still too thick but much more realistic. I could try to print some sort of forming die. It's the 2 top panel (curved ones) that scare me most.I've been enjoying the craftsmanship of this build!
I do have to say that the hood louvers, for no better word, look kinda clunky - that is well out of scale. I'm not sure that 3D printing can make them much better in that they would be very delicate. I might try, if my build, to try some thin metal, possibly shim stock. McMaster-Carr has carbon steel from .001" to .032 and in many widths. Difficult to work with for sure though. https://www.mcmaster.com/products/shims/shim-stock-6/
Hi Francois,it would scale up to a bullet proof .6 in.
Extremely cool idea. Best of luck, nice.Hello, I recently purchase an Airfix 1/12 scale Bentley Blower. I'm starting this log not because I'm starting the build, that's many months away but because I wanted to talk a bit about the ground work I'm doing and the route I intend to take. This is an old model dating back to the 70's. Airfix keeps moulding the kits using the same mold and keeps selling them. It's a very popular kit and has been done in a multitune of way, from the plain 'follow the plan' way to some major work of art with major scratch built add-ons. I started to research a bit on what had been done and fell on a Topgear article that explained how in 2020, Bentley decided to fabricate 12 brand new 'old' Bentley Blower using the original 1930's plans. They spared no expense and did a fabulous job. But what caught my eye were pictures of the body work. Like may cars of that era, the body was made of wood but unlike many others who's wood frame was then covered in sheet metal, the Bentley was covered with a material called Rexine. A flexible and water-resistant manmade material. Cheap back then, but very expensive today.
On Bentley build I found, the builders will, depending on their skills, either simply paint the plastic body, texture paint it or cover it with a fabric. I intend to go one step further by scratch buiding a wooden frame and then covering it with a fabric to be determined. So the first step was to 3d model the body using the Airfix plastic parts for dimensional references but also the pictures of the new 'old' Bentley I found. The operative word here is 'intend', I have no clue as to what kind of result I'll get but if worst comes to worst, I'll still have the plastic body to work with. Here a picture of one build in particular that is simply mind blowing and that I will be using as a reference along with some pictures of an actuel wooden Bentley frame and finally my 3d model whitch is not 100% complet).View attachment 372986
Mind blowing buildView attachment 338544
Actual wooden frameView attachment 338538View attachment 338540
My 3d model
View attachment 338542View attachment 338543
So it's a start. You might not hear from this log for a while since I've got a few other projects I wish to do first.
Thanks
