well done Mat I like special the Bitedoe very much. Yes, it is a pain to make all these gun carriages and pipes. The decks look much better now -the was too much paint between the planks a little out of scale, but after your sanding, it looks much better.View attachment 385291View attachment 385292View attachment 385293View attachment 385294View attachment 385295View attachment 385296View attachment 385297View attachment 385298View attachment 385299View attachment 385300View attachment 385301View attachment 385302View attachment 385303View attachment 385304View attachment 385305View attachment 385306View attachment 385307View attachment 385308View attachment 385310![]()
Absolutly perfect. With your permission pics from your build will go into my collection of well-builtДолго не решался делать или нет переборку кают компании, её практически не будет видно, но всё-таки решил зделать. Без перегородки как-то не по фен-шую.
For a long time I didn’t decide whether or not to make a bulkhead of the company’s cabins, it will practically not be visible, but I decided to do it anyway. Without a partition, it’s somehow not according to Feng Shui.
I have the rope and seising machines built by "LEGO BRIKS "Приобрёл вот такую машинку- клетневалку. В наличии четыре комплекта шестерней, для нитей клетни диаметром 0.1- 0.15- 0.2- 0.25 мм., и два колеса для изготовления мусинга. Был тугой ход, пришлось отполировать металлические оси, и смазать силиконовай смазкой, ход стал мягче.
I bought this type of clearing machine. There are four sets of gears for cage threads with a diameter of 0.1-0.15-0.2-0.25 mm, and two wheels for making musing. The movement was tight, I had to polish the metal axles and lubricate them with silicone grease, the movement became softer.
EXELENT
EXCELLENT SASHA AS USUAL. I HAVE DIFFICULTY FINDING MORE EXCELLENT WORDS. Later on, to align the par od deadeyes, I recommend the method below. On my last model, I made one for each pair during the building. happy building el capiЗакончил установку юферсов
Finished installing the deadeyes
View attachment 421542View attachment 421543
View attachment 421544View attachment 421547View attachment 421549View attachment 421550
Не плохие фрезы.
Смотри, что есть на AliExpress! 6 шт./комплект, Гравировальный резак из вольфрамовой стали за 356 ₽ - уже со скидкой -64%
Not bad cutters.
Look what's on AliExpress! 6 pcs/set, Tungsten steel engraving cutter for 356 ₽ - already with a discount of -64%
This is really good modeling.
