Благодарствую за ссылку, посмотрю. По моему мнению так же труба должна смотреть на нос, но на моделях из гринвича трубы смотрят на корму, вот и поставил так. Да и колпак съёмный можно и так , и эдак поставить.The chimney is looking very good - very good execution and metal work.
Often the chimneys were round, because it was easier to turn the opening into the best direction with the wind - otherwise the wind would press the smoke into the chimney
If you are interested please take a look at this topic
Stove, galley, oven, firehearth, chimney - tech. details and development over time at different navies
Friends, we know a lot about armament of the ships we are building, we can find a lot of information about framing, stern construction and also admirals and royal stores. But there are two subjects were not much information are avaiilable......sanitary and cooking In one of our last posts we...shipsofscale.com
I am not 100% sure, I think your chimney is located on the forecastle, so the opening of the chimney is towards aft -> on fixed rectangle chimneys the opening of a chimney should be towards fore, so that the smoke would disappear with the wind.......
Хм, а причем здесь Грузия?A masterpiece of Georgian elegance and grace.![]()
I don't read Russian and there was no translation so I can only guess as to the meaning of your question. But In 1781 Vanguard was a floating example of all that was best and most elegant in English artistic design of the period of the four Georges reign in England. In this case George III. So much so that period of the mid to late 18thc. became known as the Georgian Period, singled out for its' particular elegance, grace, and innovation in design across the whole spectrum of art, architecture and innovation. Your model is doing it justice and you very proud!Хм, а причем здесь Грузия?
Everything became clear, the difficulties of machine translation, and then I think that I was recorded in the Georgians.I don't read Russian and there was no translation so I can only guess as to the meaning of your question. But In 1781 Vanguard was a floating example of all that was best and most elegant in English artistic design of the period of the four Georges reign in England. In this case George III. So much so that period of the mid to late 18thc. became known as the Georgian Period, singled out for its' particular elegance, grace, and innovation in design across the whole spectrum of art, architecture and innovation. Your model is doing it justice and you very proud!
Pete
