Thanks Uwe, I saw about templates and studied your logs. Do you remember if your templates had 90 degree angle between side(vertical) line and plank lines? All 5 templates i've got are skewed, just a little bit but definitely will catch my eye and WILL drive me nuts if i don't do something about it..Unicorn Models are the manufacturer of the kit
ZHL is the distributor of the kit
Be careful
the shown elements of the inner walls are only templates - based on these sheets you have to make the wall planking
I personally made it wrong at this time and glued on top of these templates the boards - the result was ok, but now I would do it differently
USS BONHOMME RICHARD - POF - Cross Section in Pear - 1:48 - by Uwe
Very nice and clean! A real pleasure to look at! Many thanks for your kind words - I am trying (based on my limited possibilities) to build the models as accurate as possible - The good quality material and timber is here helping a lot. Hope to be able to work during the weekend some hours on...shipsofscale.com
Our member @Signet made it differently in a better way
Signet's Bonhomme Richard Cross Section [COMPLETED BUILD]
One thing I have learned about ships pumps is there were two types, and uses. The bilge pumps were to pump water overboard from the keel of the ship, from normal leaks, and rough seas, or damage in battle. They were bigger pumps with multi persons to operate them for speed and efficiency...shipsofscale.com
your framing is looking very good - clean accurate -> BRAVO
All the best,
