Here you can see a typical sketch / drawing
and the pattern sheet element 19C2 which is one front element of the magazin in the hold. They are included not as a basis for gluing the planking (laser cut strips also in photo) - really only as a pattern. If you plan not to show the back size of the wall, you can easily use these pattern also as a base and directly glue the planks on top. But I want to partly open the magazins (you will see this later in a photo) it is necessary, that these pattern sheets are not visible.
It is maybe not possible to see very well - it is my first attempt with a folio over the pattern sheet, so that the planks will be not glued against the pattern sheet - But it was not working (for me) - so a failed try
My other and next attempt was using a thin 0,5 mm veneer of pear - here you can see also the steps in the top, so my idea to be able to somehow look inside the magazin
I used the pattern sheet to mark the outside size (BTW it is fitting extremely good into the section - so the measures of these elements is extremely good)
The outside form were sanded with the circular sander / sanding disk and not cut by the scroll saw - I think this way is safer in order not to destroy the structure of the sheet
after the sanding
Not finished yet (also on top of the planks are still rests of glue etc. ) but you get an impression how it is looking like
I think I found my way to make these sheets, but I am open for any suggestions and help to make it better (or faster) - now a bigger number of sheets are to be prepared ...... step by step .....
to be continued .....
