Love the finish Uwe, oil?
Yes, I think I will use some oil for final finish - I have good experience with swedish palm oil, or some other oil..... will seeLove the finish Uwe, oil?
Such a clean work. Outstanding joinery and pear... Just lovely.Today some more work on the lower gunport(s) - but first of all I had to make some research, how the sills were installed at the Bonhomme Richard.
Due to the fact, that she was originally a french vessel, I can not fully follow books like "The Construction and fitting ..... " by Peter Goodwin.
First of all what is shown in the drawings of the Bonhomme Richard by Boudriot, here only the cross section is telling us something
....but not everything
so taking a look at Boudriots 74 gun ship - here it is much more clear shown - the lower sill is different to english ships, and has a bigger depth and ends flash with the inner planking
Here we can see the sills of the 74-gun ship
And the view from the inside - the lower sill is visible, the upper sill is covered by the inner planking -> Now I now, how to build the gunports - I have to state, that here the kit manual and the kit drawings are historically and technically wrong and I will adjust this detail like Boudriot is showing it.
The sills are installed
and so it will look like
Many Thanks for the interest ..... to be continued ......
Many Thanks for the kind comment - I enjoy the work with this kit very muchSuch a clean work. Outstanding joinery and pear... Just lovely.
Excellent work Uwe.
.....We both know that there are historical inaccuracies in this area.My question looking at the pictures is how do you propose to represent the waterway?In reality,the plank on top of the beams wasn't there.The waterway was notched on the underside to sit and clamp these beams.
I understand that compromises need to be made,otherwise more often than not it is best to start from scratch.The hard decisions we have to make are how far to take things?
Yes, I want to keep minimum one side open to get a view on the deck construction and the magazines, which will be also installed.If you are to leave areas of the decks unplanked. I would be tempted to open the tops of the mortices out to the top face on one side of the deck beams.This is an easy modification but as I am sure you are aware only one end of the carling goes into a blind mortice. The other mortice is open on the topside to allow them to be fitted in the shipyard.
Many thanks for the sketch.....Uwe
I hope this drawing makes sense.You should be able to see this on the deck plan in the monograph.To open the mortices up is a easy job with a sharp scalpel
Kind Regards
Nigel
Hallo Nigel,Uwe
Kind Regards
Nigel
Hallo Nigel,
as mentioned here some excerpts from Boudriots drawings
View attachment 127478 View attachment 127479 View attachment 127480
and some photos of my section as well from @neptune (sorry to borrow your photos), which will make the structure of the beam construction clear - no typical carlings and ledges as usual - also there are no lodging knees
View attachment 127481 View attachment 127482
View attachment 127476 View attachment 127477
Hallo Maarten,Gents, if I am correct the carlings are here fitted as Nigel mentioned.
On the left side of the carling you see it is in an open slot, the next beam to the right is only a half beam on top of the carling and the carling is fitted into the next beam right to that with a closed slot.
You see open slots for the carlings in every second beam on the right side of the beam. On the left side of the beams there are none, meaning a closed slot.
