Thank-you, Uwe and Peter for the response. I'm building the smaller barrel and it looks to be the correct size (about the dimensions of a barrel or hogshead above. I'll post a picture of the small one, next to the larger barrel in the kit so one can see how out of scale the large barrels are. It would have been nice if they provided two sizes (Butts & Barrels) or (Barrels and 1/4 casks) so they could be arranged in a less boring manner than just one size. Maybe I'll have to fabricate a few different sizes as the build progresses.found this
There were different sizes of barrels used for wine, beer, scotch, rum, sherry, beer, etc.
The type of barrels used to store water were called ‘butts’, which were approximately equated to 108 imperial gallons (130 US gallons or 491 litres) for beer or 126 imperial gallons (151 US gallons or 573 litres) for wine (also known as a pipe), although the Oxford English Dictionary notes that "these standards were not always precisely adhered to".[1][2]
(Note the different measurements for beer or wine, which is why imperial and US gallons are different but that’s a whole other story.)
The Royal Navy used a standard measurement (the wine measurement of 126 imperial gallons) so that the ship’s purser would be able to calculate and order the maximum number of butts that would fit into a ship’s hold, and the naval architects used those same sizes when designing a ship to make the best use of the hold’s dimensions.
The hold that these water butts were stored in was dark and damp being below the water line of the ship with little ventilation. Over time, the water would become foul, sometimes with algae and small organisms growing in it. (more on that later).
Because water at sea had to be strictly rationed to ensure that there’d be enough for the voyage, only one butt at a time would be lifted from the hold to the galley to use for softening the salt pork and beef that was used for stews, and for drinking under the supervision of the cooks.
When a butt was brought up to the galley it was ‘scuttled’. The word ‘scuttle’ means “to open a hole or holes”. This is where the word ‘scuttlebutt’ for gossip comes from as the sailors would take the opportunity for a little bit of chatting while they drank their water.
How was water stored in British sail ships?
Answer (1 of 5): “How was water stored in British sail ships?” There were different sizes of barrels used for wine, beer, scotch, rum, sherry, beer, etc. The type of barrels used to store water were called ‘butts’, which were approximately equated to 108 imperial gallons (130 US gallons or 491 ...www.quora.com
English wine cask units - Wikipedia
en.wikipedia.org
Very nice Brad. I had to cut some similar notches for the sills and headers on the Kingfisher. Watch out for keeping the inside and the outside the same. I had some of these turn out great - others, not so much...Today was spent working on the method to make accurate cannon ports. I am trying to follow the construction depicted by Jean Boudroit (left photo with the horizontal gunport sills cut into the frame at an angle) versus what the kit directions show (right):
View attachment 430704 View attachment 430705
First is the time-consuming job of cutting the port out with small needle saws, keeping parallel to the deck:
Next I cut into the adjacent frame to the proper depth, making multiple slits. Then used a chisel to remove the cut wood.
View attachment 430731View attachment 430740
Next, I used a surgical scalpel to cut the proper angle for the horizontal gunport frames/sills to wedge into. One side is complete (photo 2).
View attachment 430743View attachment 430744
Progress, however small is progress. I'm pleased with the result and look forward to framing the ports and see how this method turns out.
