     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Thank you very much, one grows with the task.Very good work - I like your "style"
A nice idea for the shroud fittings, Frans. About the steel bands on the hull, it’s always a trade-off between scale and visibility. Once painted it dampens the thickness.The next step is the fittings for the shrouds
A nicer approach, Franz. In scale, they are fragile, but gives the masts some elegance.Some reflections on the dimensions of the cross trees, which were indicated in my kit at a relatively robust scale of 4x4mm, 1:65(!).
Hello Peter! I was astonished by the multitude of diverse length and dimension specifications of the crosstrees in the plans, and it was only upon seeing this photo that I truly appreciated the delicate nature of the stay reinforcements. If depicted to scale, they would likely lean towards a thickness of around 1mm. I will examine this closely during construction to assess whether the proportions align appropriately or if they are indeed undersized. Time will tell. Regards, Franz.A nicer approach, Franz. In scale, they are fragile, but gives the masts some elegance.
You are doing a nice job, Franz. It’s indeed a challenge to build the winch in a representative scale. But that’s for all the detailed parts.I will slightly reduce the diameter of the raised parts on the left side. Into the cleats of the winch on the right side, a wire will be inserted each.
