….. and enough time to spend on those little buggers to be rigged ………I did a search for "rigging deadeyes" and got enough hits to spend the afternoon reading.
Yup, it’s turned into a major project. First the research, then the thinking, then the effort.….. and enough time to spend on those little buggers to be rigged ………![]()
This is all that matters…Good morning Jan and so far so good with those nasty little deadeyes. Cheers GrantThe jig may look ugly, etc. But it’s working for me.
Pesky indeed. The "JAR" has benefited quite well this week.This is all that matters…Good morning Jan and so far so good with those nasty little deadeyes. Cheers Grant
I find it humorous that once I find a solution the work progresses very quickly. I'm still a "Novice" and learning as I go.Excellent, Jan! I am glad you find a solution that works for you. You now see the value of placing all the deadeyes first, that way it is so much easier to get the heights and alignment correct. Those first two look great!
True story Jan. I am a Lazy person so I’m always looking for some jig to make matters easier. They don’t always go as planned thoughI find it humorous that once I find a solution the work progresses very quickly. I'm still a "Novice" and learning as I go.
Jan
I have to confess that this type of rigging exercise is not top on my favorite things to do list.Great work on your first two pesky deadeyes Jan.![]()
Thanks Heinrich. Going to be a long project.Quarter way there, that is good going man!
EishOooh sh...; yep, that's the wrong side.![]()
Yup, got on the wrong side of the front edge. I think a good fix is adding a couple of 1mm pieces to each side and then tapering the right “front” edge.Eish
True,true. A first for us though, I had to go to Wikipedia and look up the terminology. It takes a strange combination of weather conditions to cause that effect.Hmm, as long as it aren’t cats, dogs or hayforks you don’t have to worry I think…
